Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
ETS intake install help needed
Old Feb 11, 2009 | 07:15 PM
dragon831's Avatar
does anyone have an install for the ETS intake? I've seen one for the AMS but it's a little different. I know how to connect the inlet pipe to the turbo, the maf adapter and filter to the inlet pipe, and the inlet pipe to the bov, but there's also 2 other ports on the intake and i'm not sure what goes where. There is also a long rubber piece that im not sure where it goes either lol im assuming somewhere around the maf adapter and filter?. Help help help please!! thanks to all in advance!
Old Feb 12, 2009 | 05:06 PM
Grendelrt's Avatar
The two outlets on the back of the pipe are the same as the stock connections. Did you get the extra bung when you bought the intake? The thicker tube pops down inside the the hole with the grommet in it. The other connects to the vacuum line that came off the stock intake suction pipe, ill take a picture for you if I get a chance.
Old Feb 12, 2009 | 05:19 PM
Grendelrt's Avatar
Old Feb 13, 2009 | 03:43 AM
dragon831's Avatar
thanks a ton man!! clears up all my troubles
Old Feb 13, 2009 | 04:51 AM
Grendelrt's Avatar
No problem man, glad it helped ya.
Old Feb 13, 2009 | 11:36 AM
dragon831's Avatar
One more question, exactly where does the long black rubber piece go? Is it suppose to be used as some sort of gasket?
Old Feb 15, 2011 | 09:11 AM
stEVOrgiX's Avatar
You know that little rubber hose that connects to the BOV? Well since ETS has moved the placement of the BOV you require a longer hose. The one ETS sent replaces the shorter one so it's a direct replacement.
Old Feb 18, 2011 | 11:11 AM
black95tt's Avatar
What is the extra bung for, and should you opt for it when purchasing one of these? This will be going on an otherwise stock car.
Old Feb 18, 2011 | 03:33 PM
thisisagame24's Avatar
when i ordered mine from Mike from ETS he told me to get it. im pretty stock too
Old Feb 19, 2011 | 06:37 AM
stEVOrgiX's Avatar
If you're going to keep it stock don't need it. If you're going to mod your car you'll need it for a wideband o2 sensor. It's highly recommended if you're going to mod your car otherwise you really don't need it.
Old Feb 19, 2011 | 12:45 PM
black95tt's Avatar
We are talking about the intake here, not the exhaust.
Old Feb 19, 2011 | 05:42 PM
migs647's Avatar
So you got your intake all installed and taken care of? Bolted up the heat shield correctly?
Old Feb 20, 2011 | 06:31 AM
stEVOrgiX's Avatar
Haha lol you're right. I'm a noob
Old Feb 22, 2011 | 02:58 PM
wwEVOsss's Avatar
How loud is the ETS intake over stock? Anyone have a sound clip? Thanks..
Old Feb 22, 2011 | 05:28 PM
ToddMcF2002's Avatar
My BB can't seem to capture it. This is better anyway
STOCK: ............................................
ETS: ssssshhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh pssssssshhhhhhh!!!!!
