Problem With Hks Ssqv Bov!
Hey i installed the hks bov 2 days ago and while im driving, i get a check engine light, a service soon light, the asc off light (all flashing) and then the engine shuts off... did anyone get this problem? Does anyone know how to fix it?
looks like you're throwing multiple codes. if you're not getting your car tuned with the bov in mind, take it off. i'm going to assume you're running full vta. it's jacking up your maf sensor. sounds like it's throwing the car into full limp mode. get rid of the ricer vta bov and stay with the stock diverter valve. the factory diverter valve is very good. ricirculated is the way to go unless you get mapped for full vta.
Might want to learn more about cars, engines, turbo systems and everything else before you go modding. Considering you didn't even know what a CEL was or even how to check it... its probably wise to start that way before you go breaking your 30+ thousand dollar car just because something "is cool".
And... 5th gear 4k rpm is like 70mph.... and there is still more info that people need. Were you at WOT (thats "wide open throttle")? Cruising on the freeway at a constant speed? Attempting to pass on the freeway by applying throttle? Or passing with aggressive shifting? Hard racing/accelerating and chopping the throttle?
