Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Air spoiler ( Tall Wing) Evo X
Old May 4, 2009 | 10:16 PM
nelsondevicenci's Avatar
Thanks!
But is for the aftermarket wing, mine is oem.
Old May 4, 2009 | 10:18 PM
Yes, the third hole...has a grommet or just a hole?
Old May 5, 2009 | 07:06 PM
Blue_CobaltSS's Avatar
gromet, like a big omega symbol, a peg on the spoiler sits in it
Old May 6, 2009 | 09:19 AM
Pls any pic?
Old May 7, 2009 | 09:16 AM
Pls post a pic.
Thanks
Old May 7, 2009 | 10:12 AM
alex3dworld's Avatar
come on guys! no everybody have an extra $300 a month to burn. Gts is a good decent car. go for your wing budy!
Old May 7, 2009 | 02:27 PM
il try to get one tonight, but i destroyed the original gromet thing when i took the wing off. the gromet sits in the trunk when the wings removed, like a rubber cup. i did not want that showing so i took a screwdriver and just pryed it out so i wont have any pictures of the actual piece. just the hole where it was. il see if i can find a picture of the piece.
Old May 7, 2009 | 02:57 PM
ZeroFighter83's Avatar
Can someone post a picture of the hole circled in red without covers up close please?
Old May 7, 2009 | 05:43 PM
Bighec's Avatar
Here you go buddy.
Old May 7, 2009 | 05:56 PM
Thanks a lot bighec but yours is the lower wing like the one already have in my gts.
You need the same info I want to install your tall wing.
Old May 7, 2009 | 08:04 PM
Ltdanish07's Avatar
my head hurts..
did you get all the mounting hardware as well? if you did you should be able to figure it out.
Old May 8, 2009 | 02:47 AM
Bighec's Avatar
Ok, well I just installed a tall wing on my car yesterday afternoon, and the inner bolt was not installed. On an evo with the tall wing there is a nut welded into the body that catches the nut, and it is covered by metal on the inner portion of the trunk. So if want to put a bolt on there you need to figure out a way to squeeze a nut in there. Here are some pics. And if you look on the passenger side there is not even a place to squeeze your hand inside, so just forget about that last inner bolt.
Old May 8, 2009 | 06:55 AM
Thanks one more time Bighec.
I do it and seems like is good just with the bolt, nut and the guide so i dont need to install the other bolt under the cap.
Bighec a request for you...You can take a pic for the base of the wing i notice a space between the trunk and the bottom part of the wing.
Thanks you was so helpful!!!
Old May 8, 2009 | 07:16 AM
Ultimateone's Avatar
did you put down double sided tape again?
Where did you guys get the wings?
Old May 8, 2009 | 07:26 AM
Hassan!'s Avatar
Show us picture of before and after..
