Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
TPS Sensor wiring diagram, or gas pedal?
Old Jun 24, 2009 | 09:00 AM
DRAG's Avatar
Does anyone have a wiring diagram for the TPS sensor and actuator, or even one for the gas pedal would help???
I have looked through the service manual and I'm having trouble finding it. Mitsu manuals are horrible! Thanks.
Old Jun 24, 2009 | 09:09 AM
Excellence..'s Avatar
im sure a certified mitsubishi dealer ship can provide you with a wiring diagram, if not fix your problem for like a fortune, good luck, hope this helps.
Old Jun 24, 2009 | 11:11 AM
antics22's Avatar
If you have a copy of the EVO X Service manual, the information you are looking for should be on section 42C or PDF file GR00005600-42C.pdf
Im not sure what you are trying to do, but the TPMS sensors are all controlled via the WCM which is also tied-in to the ignition immobilizer.
Old Jun 24, 2009 | 11:27 AM
DRAG's Avatar
TPMS is the Tire Pressure Monitoring System. I need the Throttle Position Sensor (TPS).
Old Jun 24, 2009 | 11:29 AM
antics22's Avatar
Edit.
Old Jun 24, 2009 | 11:30 AM
antics22's Avatar
damn, i totally misread your post... let me dig up the TPS then... disregard my previous reply. lols
Old Jun 24, 2009 | 11:41 AM
DRAG's Avatar
If you found it I would send my wife over for a free BJ.
Old Jun 24, 2009 | 01:02 PM
antics22's Avatar
Does this help?
Old Jun 24, 2009 | 01:10 PM
antics22's Avatar
here's gas pedal
Old Jun 24, 2009 | 01:12 PM
antics22's Avatar
These are all listed on PDF file GR00006300-17.pdf of the EvoX service manual...
Old Jun 24, 2009 | 01:18 PM
DRAG's Avatar
That was EXACTLY what I was looking for. You are the man.
Old Jun 24, 2009 | 01:26 PM
antics22's Avatar
erm, dont forget to send the wifey over! lmao
Old Jun 24, 2009 | 01:33 PM
DRAG's Avatar
I'm getting her lubed up right now and sticking her in a Fed Ex box. Handle with care!
Old Jul 1, 2009 | 09:34 AM
DRAG's Avatar
Just FYI, the actual wiring on my X is different from that shown in the diagram. It says the voltage output is pin #6 (yellow-pink wire). My yellow-pink wire is pin #1 and pin #6 is solid green.
Old Jul 1, 2009 | 01:23 PM
antics22's Avatar
yea, theres a few discrepancies i've noticed too... For example, when i rewired the steering wheel harness to connect BEFORE the clock spring, a couple of the wires were listed as white, but it was pink in reality... and another one listed black/red was actually solid green! go figure...
kamote2000
Mar 8, 2017 12:30 AM
kamote2000
Feb 28, 2017 03:35 PM
Wmu240
Sep 8, 2015 06:21 PM
scoupe
May 4, 2008 09:53 AM
mrfred
Sep 4, 2006 06:09 PM
