Monday AMS test pipe install. Tips?
saturday is my birthday
I will be installing my AMS SS test pipe on Monday.
Any Tips or recomendations to have on mind before Install?
Is a one man easy instalation?
Experiences with this particular test pipe or others?
Thanks
Thanks
02 Socket for the 02 Sensor.
Breaker Bar for the two bolts on the downpipe. Mine were a ***** to get off.
Did you get some spacers for the 02 Senor? It will throw a CEL without them.
Other then that it's pretty simple.
^ +1. Let it soak in on the threads for a good 30 minutes first.
1) Do this job with everything COLD!
2) When removing the O2 sensor, make sure it's centered when unscrewing it. There's a lot of slop in the threads...easy to cross-thread. When installing the O2 sensor into the test pipe, put a little anti-sieze on the threads first. Did you buy an O2 spacer?
3) If the DP moves a little when breaking the front bolts loose on the stock cat, don't worry, the DP rides on a donut...just move it back when you get the stock cat pipe off.
4) Make sure your flanges are centered before locking everything down.
Make sure that if ur doing the job with a buddy for him not to completely remove the 02 sensor (from under the passenger seat)... thats what my buddy did... hahhaa
Easy as cake to remove.. the only problem we had as probably taking the bolts off. Anyways i had to remove my test pipe to put my stock cat on (fix-it ticket) taking it off was easy as hell.. its a 1 person job
good luck.
good luck.
Thanks guys!!!!
yes i have the O2 spacers, how did you install the Jets inside the spacer???
do i need to use all the jets or one in particular.
i'm talking about these Jets
http://www.amsperformance.com/cart/A...or-Spacer.html
Yea, the hardest part of the install is breaking the OEM bolts loose. I did it by myself and it took me maybe 45 minutes inclusive of getting my tools/jack/stands etc out of the garage and into my driveway to actually do it. I also ended up drilling out a pair of spark plug defoulers for my O2.
