Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Remove front/down pipe (not dump)
Old Aug 3, 2009 | 02:14 AM
tephra's Avatar
Hi Guys,
Anyone got any tips for removing the frontpipe (the pipe the 02 sensor goes into)?
Can I remove it whilst leaving the cat inplace or do I need to pull the cat out as well?
Cheers
D.
Old Aug 3, 2009 | 05:27 AM
GGEvoX's Avatar
Originally Posted by tephra
Hi Guys,
Cheers
D.
You can leave the cat in place...Unbolt the spring loaded bolts from the 02 housing and then unbolt the last 2 where it meets the cat. It's pretty straightforward. It is easier to get down there if you remove the strut tower brace just an FYI.
Old Aug 3, 2009 | 05:30 AM
tephra's Avatar
ok.
I was just going todo everything from under the car - use a _long_ extension bar etc...
Or do you mean the brace under the car?
Old Aug 7, 2009 | 09:38 AM
alex3dworld's Avatar
http://en.wikipedia.org/wiki/Strut_bar
sample pictures on your right hand of the web
Old Aug 9, 2009 | 01:43 AM
tephra's Avatar
yeah thats too much
im not talking about the dupm, just the frontpipe..
Old Aug 9, 2009 | 06:32 AM
rogue's Avatar
Hey, I have done this 6 or 7 times. first get the o2 sensor out, is much easier to remove when the downpipe is attached to the car. Spray all the bolts with PB blaster (I did not need it but some others have). Get a 14mm (i think) socket and two long extentions with a ratchet. 2 bolts on the top of the downpipe and 2 near the cat.
Old Aug 9, 2009 | 06:33 AM
rogue's Avatar
You do not need to remove the Cat.
Old Aug 9, 2009 | 06:47 AM
tephra's Avatar
cool thanks man
Old Aug 10, 2009 | 03:49 PM
tephra's Avatar
np
Old Aug 10, 2009 | 04:04 PM
stokEd's Avatar
Had this is my Photobucket, might help:
Old Aug 18, 2009 | 10:13 PM
roykulokoy's Avatar
yea thanks! helps when some are **** about torque specs
Kreeker
Oct 12, 2014 07:08 PM
evo854880
Apr 17, 2012 09:10 PM
sheeley91
Jan 27, 2011 05:33 PM
elmark44
Sep 28, 2010 10:22 AM
cedes14bamg
Nov 8, 2009 07:12 PM
