Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Radar direct wire install help
Old Aug 28, 2009 | 10:48 AM
monkey_187's Avatar
I am installing my radar detector using a direct wire so I dont have to use the one from the cig lighter. I need help on where to splice the wire so it gets constant power after I turn the car on. Anyone with a wire diagram and some help I would appreciate it. I need the wire to be somewhere on the passenger side under the glove box. If you have pictures of the wire and location it would help me a lot. Thanks in advance for the help.
Old Aug 28, 2009 | 01:16 PM
kenpo1441's Avatar
Don't splice...just run the wire down to the fuse box and use a fuse tap; I did it on mine and it has worked great. I ran the wire across the head liner and then down the a pillar which opens up right above the fuse box.
Old Aug 29, 2009 | 12:19 AM
►EvolutionX◄'s Avatar
Aye, Mount your radar detector by your rear-vier mirror, run the wire behind it, tuck it behind the headliner, run down through a pillar, along door jamb, into drivers fusebox, then purchase a fuse tap (search an automotive parts store) and tap in, DONE, then when you sell the car, you dont have to fix anything. SEARCH, there is a thread of someone who did exactly this.
Old Sep 1, 2009 | 09:24 PM
itznoraa's Avatar
i tapped mine into the cig lighter with add a fuse into the fusebox near the drivers foot.
also hid the wire like everyone else said.
Old Sep 3, 2009 | 10:22 PM
suprawillis's Avatar
Hard-wired my 8500 tonight. Took me 5 minutes. I have the radar detector suctioned on the left side of the windshield. The wire is tucked in the A-pillar, down to the fuse box area. The ground is mounted to a 12mm bolt inside the dash area near the fuse box, and the power source is just fuse tapped it. Took 5 minutes. Got the hard wire from ebay for 7 bucks shipped to my door.
Old Sep 21, 2009 | 08:12 PM
bouncintiga's Avatar
does the a pillar piece just pop off?
Old Sep 21, 2009 | 08:15 PM
kenpo1441's Avatar
Yes it does...there is a small plastic strap that was kind of a pain to get off, but once you get past that it comes right off. There is a nice size hole that you can feed the wire down right in front of the fuse box.
Old Sep 21, 2009 | 09:39 PM
mini fuse #13 is the cig lighter/acc fuse. it's in the minifuse compartment in the cabin.
if you go to the third row from the bottom (or forth row down), it's the one all the way to the right. should be a blue 15 amp fuse.
tap into that with a bussman and you should be set.
Old Sep 22, 2009 | 07:31 AM
chidevildog's Avatar
damn I actually did mine the fugly route.. I drilled small holes underneath my rearview mirror and tap onto the light/dome switch.. to turn it on i have to tap the dome light which i removed the bulb and tap again to turn off... I forgot to turn it off once and radar just kept blinking.. I def. have to fix it..
Old Sep 22, 2009 | 01:07 PM
Spazo's Avatar
Damn Chi... that's, um, a "creative" way of doing it.
Old Sep 22, 2009 | 03:34 PM
Actually, I was bored and it was late at night.. I started and wanted to do a clean install but didn't have the right proper tools.. After fumbling around I ended up with the above description.. It works.. still have to fix it later
FiReBReTHa
Lancer How Tos / Installations
Jul 18, 2016 08:05 PM
haystack
Outlander Sport
Dec 24, 2015 10:40 AM
daniel007
Jul 29, 2015 06:29 PM
FortMacLancer08
Nov 19, 2011 02:07 AM
jebodiah1699
Jun 4, 2008 10:06 AM
