Radar detector
Old Dec 22, 2015 | 08:04 AM
haystack's Avatar
Radar detector
Guys,
I have searched and couldnt find anything specfic. I need a radar detector. I have found the hardware I want, but I just wanted to ask if anybody has theirs hardwired?
If so how did you run the wires? I was just curious because of the airbag in the A-pillar and didnt know if it was possible to run it in that direction.
Thanks for any help
Old Dec 22, 2015 | 08:26 AM
aarhed263's Avatar
I have one that i mounted under the review mirror and powered directly from the mirror using this:
http://www.amazon.com/PerformancePackage-Mirror-Beltronics-Radar-Detectors/dp/B00RA38YIK/ref=sr_1_4?ie=UTF8&qid=1450801319&sr=8-4&keywords=radar+hardwire http://www.amazon.com/PerformancePackage-Mirror-Beltronics-Radar-Detectors/dp/B00RA38YIK/ref=sr_1_4?ie=UTF8&qid=1450801319&sr=8-4&keywords=radar+hardwire
Just push the 2 pins into the back of the mirror connector(finding power and ground obv). It turns on and off with the vehicle
Old Dec 22, 2015 | 09:39 AM
haystack's Avatar
Originally Posted by aarhed263
I have one that i mounted under the review mirror and powered directly from the mirror using this: http://www.amazon.com/PerformancePac...radar+hardwire
I dont have a powered mirror...all I have is the wiper sensor.
Old Dec 22, 2015 | 09:45 AM
aarhed263's Avatar
I think you have the same OS as me(2015 se awd).....you are sure that there is no cable running to the back of the mirror?
Old Dec 22, 2015 | 10:13 AM
krypt0nate's Avatar
I hardwired my dashcam to the cigarette lighter fuse. It will be probably the same for your radar detector.
Reason i picked cig. Lighter fuse because it turn on when ignition on and it will turn off when ignition off
Old Dec 22, 2015 | 10:15 AM
haystack's Avatar
2015 SE, from what I understand the auto dimming mirror is an option, but not standard. There is a small notch on the very edge of the headliner. I am assuming that would be where the factory wire would be if I had the option.
Old Dec 24, 2015 | 10:40 AM
Jonjon5's Avatar
I have both my dash cam and my radar detector hard wired to me cigarette lighter. I run my wires in my a-pillar but I have positioned the wires to be forward of the airbag, closer to the windshield to avoid them being in the way. There was plenty of room for it.
datdjrobp
21
Apr 12, 2016 08:18 AM
field3
Jul 2, 2003 01:14 AM
insomniac_evo
59
Mar 2, 2003 09:42 PM
