Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Installing your own clutch!
Old Oct 10, 2009 | 07:39 PM
TTP Engineering's Avatar
There are instructions on the internet on how to build a Hydrogen nuclear bomb, but it does not mean that everyone who reads it is qualified or has the tools nor the mean, nor the experience and mechanical ability to build one.
Old Oct 10, 2009 | 07:40 PM
Talon_66's Avatar
Originally Posted by ►EvolutionX◄
If you did the 02 downpipe, you can do anything. Especially with that writeup.
Thanks for the vote of confidence!
o2 was a *****, but I have had to remove it since (15m removal, 30m install)
Maybe I'll attempt this, since Im so cheap.
Old Oct 10, 2009 | 08:32 PM
kelvar13's Avatar
holy crap that seems extremely time consuming. But huge thumbs up on the writeup. Seems extremely well documented and written.
Old Oct 10, 2009 | 08:36 PM
►EvolutionX◄'s Avatar
Of course it does! What world do you live in?
Old Oct 10, 2009 | 09:23 PM
CatalystGod's Avatar
Originally Posted by tsitalon1
Calipers don't have to come off, xfer case doesn't need to come off or drained, this seems like more work then I've done, and I"ve done it twice now...will do it a 3rd time real soon
I was gonna say.... I remember seeing X's with the transmission still mounted to do a clutch replacement.
To the OP: was it a matter of choice to remove the entire transmission or was it required since you were only working with jack-stands and not a lift?
Old Oct 10, 2009 | 09:24 PM
Old Oct 11, 2009 | 12:03 AM
delkat's Avatar
Great write up!
Just a note on disconnecting batteries. Never disconnect the positive terminal of the battery first. If you need to disconnect the battery, always disconnect the negative first. If you don't disconnect the negative terminal first and you touch anything metal in the car with the wrench when you are disconnecting the positive terminal, you will short the battery to ground and your wrench will become a welding rod.
If you need to disconnect power just disconnect the negative terminal. This breaks the circuit so you don't need to remove the positive terminal.
Old Oct 13, 2009 | 06:08 PM
LapDance's Avatar
printed and laminated =)
Old Jan 24, 2010 | 10:02 AM
henryDgreat's Avatar
money saver
thanks
Old Jan 25, 2010 | 12:19 AM
goevox's Avatar
torque specs?
Old Jan 25, 2010 | 09:46 AM
MicMcKee's Avatar
Thanks for the info,
Great write-up
Old Jan 25, 2010 | 12:50 PM
motox502's Avatar
Thanks for the write-up, will be taking advantage of this really soon
Old Jan 25, 2010 | 08:12 PM
ZWingerRyRy's Avatar
Thats why its called install your own clutch. Unless your rocking a lift in your garage, if so then you should share the wealth bud
Old Jan 29, 2010 | 05:31 AM
lex08gsr's Avatar
How long did it take?
Old Jan 29, 2010 | 04:05 PM
Guru's Avatar
Will probably take you 8-10 hours the first time yo do it. IT does get faster the more you do.
