Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
help installing ageny power pulley
Old Feb 17, 2010 | 09:27 PM
diego88's Avatar
has anyone installed ap crank pulley? i need some helpfull tips
Old Feb 28, 2010 | 12:29 PM
El_Kameleon_G's Avatar
Nope but I was looking into it. I know many people here are against it because of the lack of vibration dampening. What info were you needing?
Old Mar 1, 2010 | 04:01 PM
lousEVOxmr's Avatar
removing front passenger wheel and after plastic cover then youll see the pulley there its only one bolt... if you look on there web site youll see a picture of it installed
Old Mar 1, 2010 | 04:30 PM
As far as swapping out the pulley, you should have the car in 5th gear while using a cheater bar to loosen up the bolt. Then, remove the belt and finish unbolting the crank pulley. Bolt on the new pulley, reinstall the belt, and torque down the bolt to spec.
Old Apr 30, 2010 | 08:17 PM
JED_POLAND's Avatar
Can I get some more info on that please?
Old Jul 28, 2010 | 01:36 AM
jackygor's Avatar
bump for answer!
Old Jul 28, 2010 | 05:06 PM
The stock pulley has a rubber insert that cushions the torsional vibration the engine produces. Removing it will at worst cause premature wear on bearings or engine failures.
Here is a good read that may help clear things up. http://www.atiracing.com/products/dampers/101/index.htm
Also one on "dangers of power pulleys" http://www.atiracing.com/products/da...mper_dinan.htm
Ati does sell a dampened crank pulley for our cars with a 3% reduction for about $475.
Hope this helps clarify things.
Old Jul 11, 2017 | 10:31 PM
NoNonsensePC's Avatar
Please Please Please do not install this pulley. Their is no gain for something like this. You will only experience problems.
crisdiarata
Sep 22, 2017 01:20 PM
Steve_P
Jun 28, 2017 01:44 PM
Huetsimus
Feb 17, 2017 08:23 AM
real fast
Dec 7, 2016 09:00 AM
