Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Prosport boost gauge gripes.
Old Mar 25, 2011 | 08:24 AM
Mad_SB's Avatar
Originally Posted by Skott2k
I use peak warning boost, oil pressure, egt and none of the buttons rattle at all. egt and oil are spot on but im tuned to 24 psi and my gauge hits 30 with no problem every time so im taking it that gauge is not at all accurate.
That is a very poor assumption to make, It is far more likely that you are boosting higher on the road than you were on the dyno. All gauges will have some amount of error, but not 6psi. Better check your boost.
Old Apr 2, 2011 | 09:03 PM
nhowar's Avatar
i had the same problem but came up with an easy solution. if the demand is there i can make a how-to for the 2011's.
Old Apr 18, 2012 | 06:07 PM
64deuce's Avatar
Gauge Pod
Not a super fan of the loss of visibility of the speedo and tach with the gaugepod in place, but it is a pretty clean install.
Look for either visco-elastic sheet or a product called Sorbothane (low durometer polyurethane) to take the rattle out of the gauges and pointers.
Old Dec 25, 2012 | 09:52 AM
Jyles's Avatar
I have to agree with some of the mixed reviews. I bought the Boost, AFR, Water Temp, Oil Temp, and Oil pressure gauges. THey look ssick!! However the swiss step movement can be heard all the time. If you turn on your ignition all the way with out starting the car, upon completion of the opening ceramony all the warnings come on (like it should) but when you then start the car the keep blinking and beeiping! They also change color on thier own when the car is stalled out or the prevouisly mentioned happens. The other problem i noticed is the Water Tempature is 20 degrees below what my Cobb access port reads. So how knows. I do love how they look and that the "Red" color matching the red of the OEM lights.
Old Dec 26, 2012 | 05:12 AM
Sunwalker12's Avatar
I jest installed a ProSport Boost Gauge in my buddy's EVO 8 and I'd have to agree that they are pretty spot on. I enjoy the fact that you can color match them to your factory dash and you can't beat the price. I'll give it this, it was significantly more accurate than the factory MR gauges that came factory on the car...lol
-Hum-
Dec 16, 2013 08:26 PM
mrwickd123
Aug 7, 2013 12:31 AM
Evolution Z
Feb 18, 2012 11:27 AM
RedLanEVO
Sep 8, 2006 10:25 AM
