Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Drilling through Firewall
Old Apr 3, 2011 | 04:50 AM
sun_ice4's Avatar
Where is a good place to drill thru the firewall?
I know about the typical places.
-thru the fender,
- the main rubber grommet near the drive side,
- the nearly impossible to access grommet on the passenger side.
I simply want to drill through a spot. Who else has done this, can you post some pics of where you did it?
(I couldn't find the installation request sub-forum)
Old Apr 3, 2011 | 07:40 AM
Evo&Son's Avatar
There is no need to drill. There are two excellent options available -
1) passenger foot well
2) driver side (where you swing your legs out - on the side sill) from there you route behind the right fender plastic and then you go up to the corner of the engine bay.
https://www.evolutionm.net/forums/ev...lean-hell.html
#1 I used for A/F
#2 I used for boost and shift lights.
Old Apr 3, 2011 | 01:12 PM
sun_ice4's Avatar
Yup, I'm aware of the fender one, as mentioned in my post, and would rather not go that route. Where is the passenger footwell one?? I only know of that one that's tucked in the far passenger corner, that comes out behind the glovebox.
Could you post a pic of where the footwell one is. (Or are we talking the same one?)
Old Apr 3, 2011 | 06:56 PM
lancerarmstrong's Avatar
there is a massive amount of room on the passenger side if you actually needed to ever drill, but if you're planning on just running small gauge wires into the engine compartment it's easiest to get a grommet punch and go through the main grommet to the right and up of the gas pedal.
Old Apr 4, 2011 | 08:51 AM
Evo&Son's Avatar
it's under the carpet where it angles up (where yr feet gp).
Hugh grommet. Pull carpet remove styrafoam piece. Can't miss it.
BARNSEY
Aug 27, 2007 11:15 AM
BARNSEY
Aug 27, 2007 03:36 AM
ralliart99VR4
Aug 8, 2004 08:27 PM
camdog17
Mar 8, 2004 05:47 AM
SNapz
11
Nov 6, 2003 11:03 AM
