Firewall and 4 Guage
Where can I get through and into the car using 4 guage wire? Ive seen the how to at the top but the 4 guage is not going to fit through the grommet in the door. Ive seen the one grommet in the firewall on the passenger side. I fed the wire through there but I could not reach the cable once it was in the car...
Any ideas?
Any ideas?
Use the grommet that goes into the opening between the fender liner and front fender. I had 1/0 fed through there, so you should have no trouble with 4 gauge. Plus it comes out in the left front corner there by the spray reservoir, which is a perfect place to mount a fuse holder. To get at the backside, just remove the 8 or so fasteners holding the fender liner to the fender, and you can flex it down enough to get your hands in there. Plus the wire will come out in the car right near the kick panel, so it is easy to run it to the back of the car down the sill.
I actually ran 1/0 gauge through a hole I drilled through the firewall. I popped a new rubber grommet in hole, ran wire through. You need to just go back and forth locating bolts in engine compartment that match up to bolts going through drivers side (or pass.) underdash area. This will give you a rough idea as to where you can drill through firewall without hitting anything important. Be careful though, and triple check.
Originally posted by SNapz
Would you happen to have a pic of this area?
Thanks. So I just take of the fender lining and then it is easy to access that grommet? Is it just little clips or is there also a bolt or two that has to come off?
The one on the fender.. Is that for EVO or for the Lancer? I have a Lancer and there is a grommet there however it looks extremely hard to get at. I think it might might be in a slightly different place.
For those that have drilled through the firewall can you show me a picture of where you did.
Thanks. Also there is a grommet in the engine bay on the passenger side however when I put the wire through there I have no way to get at it to pull it down. Has anyone actually threaded a wire through there?
michiganevox
Mar 5, 2011 07:25 PM
BARNSEY
Aug 27, 2007 11:15 AM
BARNSEY
Aug 27, 2007 03:36 AM
ralliart99VR4
Aug 8, 2004 08:27 PM
