Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HELP MMCS install question
Old Dec 26, 2011 | 10:05 AM
bryan9915's Avatar
I am in the middle of my MMCS swap and everything was going fine until I came to the hazards. I need to take them off and install them on the MMCS bezel. I was able to unscrew, unharness, and pop off the hazed switch panel but there is a small wire band on the right side which goes up into the oem face plate / control. Am I just supposed to pull that out some how? It doesn't seam like I should. Do I need to get the hazard switch from the guy I bought all the rest of the MMCS pieces from?
Please help as I have my dash dismantled right now.
Thanks in advance.
Old Dec 26, 2011 | 11:41 AM
bryan9915's Avatar
Pictures to help
Old Dec 26, 2011 | 03:38 PM
AFD's Avatar
AFD
It looks like that band of wires with the white plug should just pull out of the black port on the hazard's circuit board.
Not 100% sure, so don't break it!
I'll see if I can find any info..
Old Dec 26, 2011 | 03:42 PM
AFD's Avatar
AFD
Yup, step #8 from the tutorial..
Originally Posted by antics22
8) With bezel free from the dash, unclip the harness from the hazard switch and completely remove.
Now, you should be able to see the double din head unit thats hidden behind the pretty dash bezel. (it is held by 4 phillips screws).
https://www.evolutionm.net/forums/ev...-evo-10-a.html
Old Dec 26, 2011 | 04:05 PM
bryan9915's Avatar
Thanks but I did that. The wiring harness unclipped like it should. This is a separate wire that appears to be directly wired between the radio controls and the hazard control .
Actually, as I write this I think I know what it is. There is no wire harness to the radio face plate so it must go through the hazard. Can anyone confirm?
So question is if I cut it obviously the radio face plate us useless but will it then work separately with the MMCS set up without issues. HMMMMM
Old Dec 26, 2011 | 04:32 PM
AFD's Avatar
AFD
Not sure.. but I'd definitely try prying it out of its connector again, before cutting it.
Lots of luck man!
Old Dec 26, 2011 | 05:25 PM
bryan9915's Avatar
Ok I got it. IT took some guts and at first I thought I broke it. But the wire does pull out of the hazard chip board (or what ever you want to call it) So if any one else is worried just be careful and have some guts.
AFD thanks for the courage. HAHAHA
Old Jan 23, 2012 | 11:27 AM
mbnworld's Avatar
its just like a computer ribbon on a motherboard just smaller.
flawny
Jul 30, 2016 04:30 PM
Dynafit
Oct 16, 2015 01:46 PM
Senvae
Dec 22, 2013 12:25 PM
Doctor Murdock2
Sep 7, 2012 07:34 AM
