Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Cusco Rear diff install
Old Mar 2, 2016 | 01:11 PM
MR.SScott's Avatar
Veteran: Army
Originally Posted by sammyrex
Where can you buy the side bearing? I have looked into many difference sources, just can not find them. Anyone knows? I am planning on replacing my rear diff with Cusco RS 1.5 way. Thanks for your input.
HA! Me too. My idiot local dealer just told me that I'd have to order the entire rear diff.
Old Mar 3, 2016 | 12:32 AM
deylag's Avatar
MB393957
It could be because they dont have the complete catalog. I was looking through the USDM catalog and it's missing a couple pages. Then I went looking through the JDM catalog and found it. Also has different size shims too.
Old Mar 4, 2016 | 09:46 AM
splattj's Avatar
Yeah, it looks like the US catalog is missing it. Weird.
Here's a diagram with part numbers:
http://www.partsbase.org/mitsubishi/...ferential-p-4/
Old Jul 19, 2018 | 06:33 PM
Lightsaber's Avatar
Allow me to chime in with a chart.
It looks like to install the Cusco 1.5-way rear LSD, we need the AYC-compatible LSD itself (p/n LSD 452 L15) and two side bearings (p/n MB393957). Let me know if this is correct.
I also wonder what is the most ideal setup for autocross. Keep the stock front open diff (risk of diff failure because it's weak)? Use a Cusco 1.5-way front LSD too (p/n LSD 454 C15 or LSD 453 C15)? Or some other choices like the recently popular Wavetrac ATB front LSD?
Old Jul 20, 2018 | 08:04 AM
kaj's Avatar
kaj
Originally Posted by EvoTurboTurk
Could you fit this on a evo 7 rear diff with ayc? does it require other parts like bearings etc?
You need CUS LSD 448 L15. I actually have an extra, if you are interested. It has brand new bearings installed.
Old Jul 20, 2018 | 03:54 PM
Lightsaber's Avatar
Any info on how Evo performs the best? Open diff front and rear, LSD rear, or LSD front and rear?
Old Jul 20, 2018 | 03:59 PM
kaj's Avatar
kaj
General consensus I'm getting is a clutch-type LSD in the rear with something like Wavetrac or Quaife up front. Open diffs are never good. Ever.
Old Jul 20, 2018 | 04:12 PM
Lightsaber's Avatar
So you mean something like Quaife or Wavetrac LSD front and Cusco Type-RS 1.5-way LSD rear produces the best performance? I guess that makes sense.
I also heard that Quaife and Wavetrac front LSDs are much stronger than the stock front diff, which is prone to blow up when autocrossing. Not sure if the Quaife and Wavetrac front diffs are truly much stronger though.
Old Jul 20, 2018 | 06:11 PM
kaj's Avatar
kaj
Yeah, That is an example. So I'm told, though. Someone always hah an opposite point of view though LOL.
Wavetrac and Quaife are stronger but I've never heard of an OEM front diff grenading. Maybe I just haven't been around when they do.
Old Oct 10, 2018 | 01:23 PM
kyoo's Avatar
Originally Posted by Segfault
So thanks to Mert at GST, I got my Cusco RS 1.5way rear diff installed.
Attachment 315151
So like any diff install, you gotta get those half-shafts and drive shaft out of the way first. Disconnect the AYC lines, 3 bolts, and the diff comes right out. After that, you unbolt the side of the pumpkin that houses the rear diff.
Attachment 315152
Then you just slide the old diff off, unbolt the main gear around it, and transfer that gear to your cusco diff.
Attachment 315153
You can attempt to transfer the old side bearings too (the ring of bearings on the top of pic 2), but that's definitely not something for the timid. It's better and safer just to buy new ones.
After that, you just bolt everything back together and put the housing back in place. Put new SVG fluid in the diff part, ATF SPIII in the AYC part, and then bleed the lines. Thankfully, I was able to use the new application from Tephra to do that part.
What is the part # for the side bearings?
never mind, i see it's covered here: MB393957 (same for 8s, 9s, 10s)
What is MB393956, the differential pinion bearing? do I need one of those to install a new diff also?
Old Oct 23, 2018 | 08:13 AM
LetsGetThisDone's Avatar
Pinion bearings don't need replaced when replacing the diff carrier. However, you will need check and possibly reset carrier bearing preload and the back lash for the ring and pinion gears. This is not exactly a DIY job.
Old Oct 23, 2018 | 09:43 AM
kyoo's Avatar
shop is doing it for me thankfully, he just asked me to get new oem diff bearings.
evotuner04
25
Feb 10, 2017 07:55 AM
evotuner04
For Sale - Part Outs
21
Feb 1, 2017 12:22 PM
evotuner04
13
Dec 2, 2016 10:09 AM
evotuner04
14
Nov 24, 2016 03:41 PM
RS200
May 27, 2016 10:52 PM
