Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
replacing alternator belt?
Old Jan 12, 2012 | 06:50 PM
NorthernLights7's Avatar
my alternator belt snapped and i was trying to figure out what size each of the bolts on the pulleys is. i have a 2003 lancer es
i know the first bolt i need to take off is in the front left pulley facing the passenger tire, and the second one i need to take off is connected to the frame in the back close to the cab, facing forward. but thats all i know so i was hoping to obtain a bit more information on just how i should go about this, ive never replaced a belt so this is a first for me
thanks!
Old Jan 12, 2012 | 06:54 PM
WHTEVO's Avatar
You should have some type of tensioner on it. You should not have to take pulley's off to change a drive belt.
Aaron
Old Jan 12, 2012 | 07:19 PM
Aaron
okay yeah i believe there is that will make things easier, then ill pretty much have to loosin the tensioner take off the serpentine belt replace the alternator belt and put everything back on in a sense, word
Old Jan 13, 2012 | 12:55 PM
Update guys:
I have searched and searched on the web for pictures as to where my tensioner bolt is located. As I have said before, this is the first time I have really done anything on my car.. If someone would be willing to point me in the right direction it would be greatly appreciated.
Thanks in advance for any help guys!
Old Jan 23, 2012 | 10:53 AM
mbnworld's Avatar
is this a 2003 lancer not an evoX. right
Old Jan 23, 2012 | 10:54 AM
khmerguyx's Avatar
^^^ I think it is
Old Jan 23, 2012 | 11:02 AM
mbnworld's Avatar
03 lancer doesnot have a spring loaded tensioner like an exoX has. will check my service manual and post more.
Old Jan 23, 2012 | 11:11 AM
mbnworld's Avatar
both the 1.6l or 2.0l you have to loosen the power steering pump and remove that belt first them loosen bottom mounting bolt on altenator just alittle and loosen top bolt on upper altenator bracket and loosen long bolt that goes trough the bracket, install belt and tighten long bolt to tension belt and tighten short bolt on upper bracket then tighten lower mount bolt and nut, dont forget this step or nut will eventually fall off and could cause lower bolt to back out. then put p/s belt back on and use prybar to tighten belt and then tighten pump mounting bolts.
R/TErnie
190
May 22, 2026 07:59 AM
Lightsaber
Jun 7, 2017 03:58 PM
onix175
Lancer Engine Tech
Feb 19, 2016 04:54 AM
BlackBeast
14
Dec 3, 2010 05:18 PM
mfr122887
Mar 18, 2008 01:32 PM
