Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
ACD/AYC Pump Replacement
Old Apr 13, 2013 | 06:28 PM
  #46
adrianTNT's Avatar
Anyone knows if there is anything that has to be done at dealer with MUT III tool after rebuilding the pump (some calibration maybe) ?
I keep taking mine apart and after putting it on the car it works for a while, 1-2 hours, then error returns.
I am close to putting gas on it and just burn it.
Old Apr 13, 2013 | 06:41 PM
  #47
manthny18's Avatar
so there a member that rebuild he pumps who and how much?
Old Apr 13, 2013 | 08:51 PM
  #48
thekhmer's Avatar
i believe the person you are talking about is from canada..i cant find the thread right now
Old Apr 21, 2013 | 04:28 PM
  #49
nautica2o3's Avatar
You might have to bleed the lines. Air gets in the system when you disconnect the lines to the pump. That's what the MUT III tool is used for.
Old Apr 21, 2013 | 05:26 PM
  #50
adrianTNT's Avatar
I was thinking that there are other things the MUT III does besides bleeding.
We did a bleed without MUT, just by gravity after fixing the motor, errors are gone but they reappear when the differentials are supposed to start working (e.g accelerating in tight corners). I will try a bleed at the dealer this week.
Old Sep 9, 2013 | 03:28 PM
  #51
LimitedSlip7's Avatar
Has anyone been able to source a replacement motor for the pump yet? I took mine apart and the motor is toast. Pulled the motor apart and it appears one of the brushes exploded. Anyone know where I can get replacement brushes?
Old Sep 9, 2013 | 08:24 PM
  #52
spekil's Avatar
I read a forumer before who rebuilt his acd pump and sent his acd motor to an electrical shop to be reconditioned. Most electrical motors use the same principle so an electrical shop should be able to help you out with that.
Old Nov 7, 2014 | 01:19 PM
  #53
limx's Avatar
Hi,
I know this thread is old, but got a question.
I've been driving my Evo X MR with the AYC/ACD lighst on and always show ACD service requeried, the lights is because of the AYC pump failure? or it could be a selenoid or the pump fuse?
I'm outside the US, so I must be sure if it is the pump failure, because I'll buy one soon.
JDMEvoVII
Oct 20, 2016 10:03 PM
TedMitsu
Aug 28, 2015 06:25 AM
rallibiz
Jan 15, 2015 07:01 PM
shadow_X
Jan 7, 2014 11:48 PM
Northchuck
Lancer How Tos / Installations
May 1, 2010 05:19 PM
