Functional Tow Hook Install
Is it possible to install a functional front tow hook at the location on the front crash beam behind the little door? When I tapped it out for the pilot hole I assumed I could tap it with the proper thread tap but found the beam to be hollow and aluminum. Therefore, I assume that if you were to drill through and then put a bolt on the back side of the crash beam, I don't think you'd wanna tow the vehicle with that thin piece of aluminum.
*Disclaimer: Searched threads and forums and unable to locate info I seek.*
I have a dual exit exhaust and can weld a bolt to the back frame but I would think a weld on aluminum would be as weak as running the hook through the crash beam. I'll talk to a welder, thanks!
LagginTimes
37
Nov 8, 2016 07:27 AM
migs647
Aug 30, 2016 05:32 PM
FS[MidWest]: JDM rear crash beam
beetle_orange
Dec 11, 2015 08:00 PM
