Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
DP install?
Old Sep 24, 2012 | 01:22 AM
Wraiths_Zero's Avatar
Question DP install?
I did a search on the forum but could'nt find any write up on how to install a DP, I'm just looking for the most PAINLESS and quickest way to do this myself.
Old Sep 24, 2012 | 05:14 AM
SUBIIKILR's Avatar
what guides have you found for the dp install?
Old Sep 24, 2012 | 11:38 AM
Vostok 7's Avatar
There is no painless way to do it. Even the turbo manifold was easier.
There's one nut that is just impossible, and that's assuming you don't have any studs break.
Old Sep 24, 2012 | 12:21 PM
Fall of pride's Avatar
ya, i did this install by myself the other day and its a huge pain in the ***, no other way about it! have you done many other installs? also what brand downpipe is it?
Old Sep 24, 2012 | 09:42 PM
gas's Avatar
gas
dp install
Put front on jack stands, take off heat sheild on turbo, spray pb blaster on everything that your taking off. Unbolt rest of exhaust from dp, and believe or not most of the bolts are easier to get to through the engine bay. After you got all bolts, slide it out the back, and install new one. Get ready to cuss...alot. I hope I helped a little.
Old Sep 25, 2012 | 08:42 AM
donzilla2004's Avatar
Yea the dp is a pain. I believe the bolt on the right side is really the main butt kicker, I would see what you can do from underneath, but it may be easier to access the bolts from the top side with the heatshield off of the turbo. Def spray everything down with PB blaster. Good luck.
One of the biggest issues is that when you put a bigger dp on the bolts are a pain to get even with a swivel socket.
Old Sep 27, 2012 | 08:05 PM
HAULIN A's Avatar
I was 5 hours to get 7 bolts out
Capdevila
Toronto Lancer Club
12
Feb 15, 2011 12:46 PM
Por2geezSupra
Dec 9, 2007 10:59 PM
xfreakx
14
Aug 31, 2007 01:45 PM
Thugline
31
Jun 4, 2007 05:27 PM
jeffbum
May 27, 2007 10:56 PM
