Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Ohlins Evo X Coilover install by RallySport Direct
Old Aug 27, 2013 | 02:34 PM
RallySport Direct's Avatar
Silver Sponsor
Ohlins Coilover Install
Installation Difficulty 2.5 out of 5
Installation Time (about 1 -1.5 hours)
Tools Needed:
-Flat Head Screwdriver
-6mm and 5mm Allen Wrench
-12mm Wrench or Socket
-14mm Wrench and Socket
-17mm Wrench and Socket
-19mm Wrench and Socket
The Coilovers we installed can be found at the link below.
Ohlins Road & Track Coilovers Mitsubishi EVO X 2008-2014
Ohlins Packaging
Everything you will receive in your packages
Got to Love that Gold on the Ohlins
Before we installed the the Coilovers they needed to be assembled.
Assembly was pretty straight forward just make sure you install your 10k front springs on the Front Struts and 7k Rear Springs on the Rear
Front 10k Springs Part #47010-31/100C 022
Rear 7k Springs Part # 47010-19/70C 022
Installation:
-Remove your wheels and tires to give you all the room you need to remove your stock suspension and install your new coilovers.
If you have a lift before raising the car up you will want to loosen the 3 - 14mm nuts on top of your front Struts on each side.
From Down below on the back side of the front struts there will be a 12mm nut holding the brake line and sensor wire bracket.
Removing this nut will allow you to remove the bracket with lines from the original struts.
Using a 19mm Open end wrench and 19mm Socket remove the 2 nut and bolts on the bottom of the Front Strut Assemblies.
Once these have been removed you can loosen the top 3 -14mm nuts to remove the old strut. Re-installing will be in the reverse order
60k miles with winter driving has started to show its use on the stock suspension.
Front Suspension Torque specs are as follows:
For the 3 -14mm nuts on top of the strut assembly 33 +- 3 Ft-Lb.
For the 2 -19mm Nuts and bolts on the Bottom of the struts assembly 81 +/- 8 ft-lb .
To start on the Rear Assembly you will need a Flat Head screwdriver to to remove the interior plastic.
Start by removing the trunk carpet.
Your will next step will be to remove the clips that hold the plastic cover over the Battery and Washer resistor.
2 Clips on top.
And two Clips on each side.
Once all 4 clips have been removed pull the plastic cover down and out.
Next Step will be to remove both side carpets.
There are two clips on both sides that hold the carpet in now.
These are threaded clips so simply twist to the left to loosen and pull off.
You will now have access to the top 2 -14mm nuts that hold the top strut assembly to the chassis.
With your 14mm Socket loosen both nuts on top of the strut.
The one on the back side is a little tricky to get to and undo as you do not have that much room but its not too bad
A view of both nuts from inside.
Once both of these have been loosened you can now work on the lower side.
Using a 17mm socket and wrench you can loosen and remove the lower bolt that holds the Strut and Lower control arm in place.
With the lower bolt removed you can now remove the top 2 -14mm nuts and remove the rear strut assembly to install your New Ohlins
Install in the reverse order.
Rear Suspension Torque Specs are as follows:
For the 2 -14mm nuts on the top of the strut assembly 33 +- 3 Ft-Lbs.
For the 1 - 17mm Nut and Bolt on the bottom of the assembly 52 +/- 7 ft-lb.
A nice part that Ohlins has included with these coilovers is the remote adjusters for Damping/ Rebound for the rear.
There is one for each side in the rear.
This will allow you to easily adjust your damping and rebound with the turn of a knob with out having to remove the trunk interior.
This hole in the rear of the chassis I found to be a great location spot to have adjuster knob sitting that will not be covered once all the trunk interior parts are back in.
I fished the end that goes into the top of the strut assembly like shown in the picture below.
This will connect into the top of the strut like shown below.
Using the provided Allen tool you can tighten the little Allen screw to hold the remote adjuster in place.
Installed remote adjuster
Reinstall your trunk interior and you will now be able to easily access the adjustment knobs
When you are all done reinstall your wheels and Make sure to torque your lug nuts before trying out your new suspension
To adjust your Damping/ Rebound on the front struts locate the little knob on the bottom of the Ohlins strut assembly.
Left to soften Right to stiffen.
Same with the rears, but you will have easy access with the provided adjuster knobs.
Before Ohlins installed
After Ohlins installed
Some cool Professional installed pictures of the Ohlins to show off
Last is a pretty cool cut away shot our company photographer did
If you have any questions or concerns on how to install please feel free to let us know.
Thank you,
-Dallin
Old Aug 28, 2013 | 10:55 AM
st0k3d's Avatar
I could make love to those.
Old Aug 28, 2013 | 11:07 AM
Silver Sponsor
They are really, really nice
Thanks,
-Dallin
Old Aug 28, 2013 | 11:22 AM
Noize's Avatar
EvoM Administrator
This is gonna be my first "big" mod.
Old Aug 28, 2013 | 11:55 AM
Silver Sponsor
These really are extremely nice! Quality is TOP NOTCH and the ride is honestly one of these best I have ever felt in a car with coilovers
I am saving my pennies to put Ohlins on my Personal Evo 8 after feeling these on the Evo X
If anyone has any questions on these coilovers please do not hesitate to ask
-Dallin
Old Aug 28, 2013 | 03:19 PM
st0k3d's Avatar
It is a shame they get dirty in the wheel wells.
Old Aug 29, 2013 | 04:19 PM
Silver Sponsor
Ya it really kind of is, but they get cleaned down about once every other week when the wheels get a good wipe down too
Take care of your parts and they will stay in good shape for you
-Dallin
Old Sep 1, 2013 | 03:18 AM
RaX's Avatar
RaX
Excellent write up Dallin. One question I have though is, are the torque specs you listed for both the front strut and rear shock lower bolts from a recent Evo X service manual? Because in both the 2010 and 2013 service manuals, I'm seeing different numbers.
Front struts: Lower bolts both 81 +/- 8 ft-lb (compared to your 123 +/- 7)
Rear shocks: Lower bolt 52 +/- 7 ft-lb (compared to your 65 +/- 7)
Old Sep 3, 2013 | 08:50 AM
Silver Sponsor
Thank you sir To be honest I Google Searched "Evo X Suspension Torque Specs"
It pulled up this thread here on EvoM - https://www.evolutionm.net/forums/ev...cs-thread.html
Now that I go back an look at this thread I actually see that its in the Evo 1-9 section. Google you confused me again
I will take your word for it on the Service Manuals number you found and update this thread if that's okay
I apprentice you bring this up to my attention
-Dallin
Old Sep 3, 2013 | 11:11 AM
ikt's Avatar
ikt
question:
Is there less tension (so easier to pull the struts out) if both struts are pulled at the same time, or is it better to do them one at a time?
Old Sep 3, 2013 | 11:18 AM
Silver Sponsor
Originally Posted by ikt
question:
Thank you for this questions.
On the fronts we did them one at a time and it was fine, but on the rear it seemed to be easier having both sides bottom bolt of the struts removed so there was less tension from the sway bar to the other side.
Let me know if you have any other questions or concerns
-Dallin
Old Sep 12, 2013 | 06:31 PM
EvoGsrLover's Avatar
On a scale of 1-10 how hard would you rate this install? and how long would you say it takes if you are doing them by yourself?
Old Sep 13, 2013 | 09:08 AM
Silver Sponsor
On a scale of 1-10 its about a 4-5ish and installation time for someone that has never done this before with these coilovers I would say close to 2 hours to have it all said and done with a friend helping
I guess it also depends on if you have access to power tools and a lift that can really make installation easier.
Kind Regards,
-Dallin
Old Sep 19, 2013 | 01:49 PM
bstgsr's Avatar
Awesome write-up! I will be following this when I install mine. I ordered them from you June and with work jusst havent had the time to get them installed. Big thanks for the information given and all my questions answered before I purchased.
Old Sep 19, 2013 | 02:06 PM
Silver Sponsor
Thank you for the complement on this What are you waiting for its been a while now I have been there and done that before having a part for my personal car and the part just sits waiting to go on the car
Let us know if you run into any other questions or concerns when installing and no problem on the before questions. I am always happy to help out were I can
-Dallin
