AEM e 320 lph fuel pump
Hey everyone,
I recently purchased a AEM e 320 lph fuel pump, as I wanted to run e85 fuel.
The issue I have (which I didn't realize till I went to install it), is that the AEM fuel pump is not a direct replacement of the stock one, as it was almost 2" too longer.
Do I need to find an aftermarket fuel pump hanger or install it in another location? Though it does say "in tank" fuel pump.
Has anyone installed this without running a dual tank set up?
Please message me your advice.
Thanks,
Rebecca
Thanks,
Rebecca
Yes if its the green ethanol pump from aem you need a hanger like map or other company. I believe its the same size as there normal black 320lph pump. Ive been looking at the same pump does it come with everything that is need minus the evo x install hanger. ie strainer and ethanol hoses? Also does there have to be any rewiring to run this pump?
Lil Evolution X
Aug 17, 2014 10:08 PM
