Another silly HID question
2011 WW X GSR
Bought a set of depo factory look projectors, happy with them.
But i can't stand nor see for crap with the composite bulbs.
So I'm in the market for an HID conv. kit.
Did a little bit of reading/research but I'm a little hesitant to buy as I don't know the exact wattage/bulb type specifically for my X.
I do know it is not a DRL setup (thank god), but I don't sit at ease with what most companies state as for the legit types.
IE: 35w, 55w, D2, 9006 etc...
Anyone able to shed a little light on the situation, or even have a recommendation?
I was looking into a kit from DDM but I want to make sure I have the right type/style for the evo before I play the return because i ordered the wrong type game
Appreciate the help guys and gals!
.Appreciate the help guys and gals!
I really hope you're installing these HID's into projector housings.
You can get most of your answers by just googling "HID Faq"
35w/55w = visible difference in how bright they are. 55w obviously is brighter, but it also burns hotter and many people worry that the increased heat/energy will damage their housings/other things.
Most HID kits are for off-road use only.
IIRC, our bulb size is D2S, bixenon.
If you're buying a kit from DDM, just give them a call and ask them. They'd be more than happy to answer all your questions and help you choose the correct kit.
In my experience the 35w last longer than 55w. One of my 35w ballast on my IS250 finally died after 7 years of use while my 55w one from my CX-5 burned out after 2 years. I probably got unlucky though as they should last more than 2 years regardless.
Mellon Racing
Nov 26, 2016 01:34 AM
TxFAkuma
Sep 30, 2015 08:55 AM
