Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Driven fab v3 catch can/coolant expansion tank
Old Jun 22, 2016, 01:36 PM
kevin salazar's Avatar
Has anyone installed the driven fab v3 on their evo x?
Old Jun 27, 2016, 06:45 AM
jakgal04's Avatar
I have it, absolutely love it. I'm actually impressed with how much **** it collects
Old Jun 27, 2016, 11:55 AM
Was it an easy install?how did you do it?
Old Jun 27, 2016, 02:56 PM
jakgal04's Avatar
The install was really easy, took me 10 minutes. The hardest part was reaching the bolt underneath the can.
Heres the write up for the install.
Old Jun 27, 2016, 03:24 PM
I got that installation but I'm just confused on the driver side breather like where do I put the plug on because I know one goes on the intake manifold but where does the other goes to?
Old Jun 27, 2016, 04:15 PM
jakgal04's Avatar
So you know both hoses go from the valve cover to the catch can? Normally it goes Valve Cover -> Intake Manifold and Valve Cover -> Intake. So the little rubber plug goes on the intake manifold and the other on the intake.
Old Jun 27, 2016, 04:29 PM
Can you send me a pic to the intake one?
Old Jun 27, 2016, 04:44 PM
jakgal04's Avatar
This is on an ETS intake, but its the same concept. You just need to put the rubber plug on the adapter on the intake pipe.
Old Jun 27, 2016, 04:50 PM
[QUOTE=jakgal04;11633466]This is on an ETS intake, but its the same concept. You just need to put the rubber plug on the adapter on the intake pipe.
ok I know where it is exactly now thanks for the help
But before you took out the reservoir out did you pump the coolant out? Since the kit comes with the pump
Old Jun 27, 2016, 05:06 PM
jakgal04's Avatar
I didn't pump it out, I actually still have the reservoir on my shelf with coolant still in it lol
Old Jun 27, 2016, 05:20 PM
But you added coolant after the install in the radiator?
Old Jun 27, 2016, 07:08 PM
jakgal04's Avatar
I checked, but didn't have to. Keep in mind that reservoir is just an expansion tank so it rises and sinks when the car is hot/cold.
Old Jun 27, 2016, 08:21 PM
So coolant should just flow into the expansion tank by its self?
Old Jun 28, 2016, 06:53 AM
jakgal04's Avatar
Yup thats correct. You'll see once you install it theres no way to put coolant in it anyway
Old Jun 28, 2016, 07:01 AM
Ok good to know
So how every how long are you suppose to pump out the what's in the expansion tank?
Quick Reply: Driven fab v3 catch can/coolant expansion tank
