Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Sst temp gauge??
Old Jun 30, 2016 | 06:45 PM
LB_Reddy's Avatar
Sst temp gauge??
Evo x mr Sst tranny temp gauge??where do i t_off the sensor to cooler line?any pics??
Old Jul 1, 2016 | 06:33 AM
splattj's Avatar
You have a few options. You can get a (or have your) drilled/tapped oil drain bolt and install the sensor in it. You can buy an aftermarket transmission pan like SSP sells where there's a port for the sensor already tapped. Or you can put an inline adapter in your cooler line. You'd want the oil feed as that is the temperature of the oil coming out of the transmission.
Old Jul 1, 2016 | 11:36 AM
LB_Reddy's Avatar
Theres 3 drain plug on the sst and 1 port next to it?ok to tap in that port?
Old Jul 1, 2016 | 04:14 PM
splattj's Avatar
You'll want one of the 3 drain plugs. SSP recommends the one on the passenger side of the car.
Old Jul 1, 2016 | 11:31 PM
LB_Reddy's Avatar
Thanks.,sst drain plug size??
Old Jul 2, 2016 | 01:40 PM
splattj's Avatar
It's either M16x1.5 or M18x1.5. I honestly can't recall. You can get both adapters from options auto salon.
http://www.optionsauto.com/prodinfo....er=TP-16400721
http://www.optionsauto.com/prodinfo....er=TP-16400722
Might want to order both if you can't find the answer elsewhere. Sorry!
evo_nation
Dec 30, 2015 05:56 AM
Subi.convert
Mitsubishi TC-SST Discussion
Oct 22, 2011 10:16 AM
auto228
Dec 18, 2010 08:06 PM
nemosEVO
Mar 27, 2008 01:07 AM
edison
Sep 24, 2006 09:54 AM
