The Ultimate Aggressive Wheel Thread... Evo X Style
Old Jan 6, 2010 | 09:27 AM
  #1336
lpy2009's Avatar
Q. I want to run 9.5" +15 or some crazy low offset?
-Not recommended: At any point where the wheel/tires begin to stick out of the fenders instead of being tucked in will result in an increase in drag. You will lose mileage and performance. Your turning radius will begin to deteriorate, and your suspension will become strained from the exaggerated track width.
-The 9.5" +22 offset is already very aggressive and at the very edge of the fenders. Any further out and your side skirts, doors, and rear quarter panel will become sandblasted by the road debris kicked up by your tires.
saw this on evoxforums , wanna ask you guys with awesome flushed setup if it is true cause i plan to run 18x9.5 +12 in the future
Old Jan 6, 2010 | 09:33 AM
  #1337
OakosAutomotive's Avatar
I don't think 18x9.5 +15 sticks out past the fenders (if anything, a 1/8th inch lol). I know 18x10.5 +15 does.
Bart
OAKOS Automotive
Old Jan 6, 2010 | 01:26 PM
  #1338
TWM Performance's Avatar
WOW...some incredibly nice setups in here!
Patrick
TWM Performance
Old Jan 6, 2010 | 02:55 PM
  #1339
raytrix's Avatar
How about 18x10 +15? How much does that stick out?
Old Jan 6, 2010 | 02:56 PM
  #1340
cpunlamd's Avatar
With out crazy negative camber.... About 1.5 inches (mexi-flush)........
Old Jan 6, 2010 | 03:01 PM
  #1341
cpunlamd's Avatar
Bart
OAKOS Automotive
It does (a few mm). 18x9.5 +20 will be flush as can be with out poking out. (this is with minimal camber)
Old Jan 7, 2010 | 07:57 AM
  #1342
That will poke considerably. You'll have to run about -3* of camber with a semi stretch to stay within the fenders.
Bart
OAKOS Automotive
Old Jan 7, 2010 | 05:09 PM
  #1343
Speed Element's Avatar
Just Traded the AME TM02 for some Advan RS in 18x10 +15 w/ Toyo T1R 275-35-18 and -3 Degree Camber all around
Old Jan 7, 2010 | 05:39 PM
  #1344
raytrix's Avatar
Originally Posted by Speed Element
Just Traded the AME for some Advan RS in 18x10 +15
What tire size and chamber you have at the front and rear? That looks hella flush and something I'm trying to achieve.
Old Jan 7, 2010 | 05:52 PM
  #1345
Toyo T1R 275-35-18
and
Old Jan 7, 2010 | 06:14 PM
  #1346
jd888jd's Avatar
Toyo T1R 275-35-18
and
Did u have to go to a all wheel alignment shop?
Old Jan 7, 2010 | 06:16 PM
  #1347
I'm sure any alignment shop should be able to max out the camber for you
Old Jan 7, 2010 | 06:51 PM
  #1348
cpunlamd's Avatar
You dont need to pay anyone to do that. Just loosen the 4 allen key bolts on your camber plates, and push those suckers full negative.
Old Jan 7, 2010 | 06:54 PM
  #1349
DaFastOne's Avatar
You will ruin your toe if you do that.
Old Jan 7, 2010 | 07:02 PM
  #1350
raytrix's Avatar
I got Stance LX+ and my tuner shop of choice I go to is Touge Factory. I'm sure they will be able to max the chamber to -3 if needed. I just didn't know how far I need to go. I plan to wear 265/35 R18 tires so I'm thinking I can get away with -2.75 front and -2.5 rear.
