Rexpeed Evo X Hood Dampers
Old Nov 21, 2008 | 10:15 PM
TruboPower's Avatar
Very nice, Wish there was a little more finish on the fender brackets though,the gold bolts with washers seem a bit outta place
Old Nov 21, 2008 | 10:49 PM
Rexpeed's Avatar
Thanks for the review glad you like them
Regarding the washer and bolts you can always buy different colors ones at any hardware shop
I will be putting these hood dampers on our website in a few minutes.
Thanks,
Derek
Old Nov 22, 2008 | 10:01 AM
TheBlueBlur's Avatar
sweet. I'll be picking these up for sure.
Old Nov 22, 2008 | 10:16 AM
saulbyu's Avatar
Originally Posted by beetle_orange
so with this you dont need the stock steel that holds our hoods up?
That is correct. I actualy took mine out and removed the plastic clip that holds it in place and it looks clean!
Old Nov 22, 2008 | 12:01 PM
macPSU's Avatar
Hood dampers are probably my favorite "mod" so far. I love the fact that I don't have to use the ugly steel rod to hold my hood up anymore. I do think the car should have come from the factory with dampers though.
I have Gruppe-S carbon fiber dampers by the way, which are a universal fit for Evos 8, 9, and 10. They work great, but I do have to say the Rexpeed ones look to be a better fit since they are made specifically for the X.
Old Nov 24, 2008 | 04:27 AM
Rexpeed's Avatar
Thanks for the orders guys
Derek
Old Nov 24, 2008 | 06:53 AM
tannerc's Avatar
I know this is the Evo X forum, but I just have to ask: would these dampers fit on an 08 Lancer ES?
Old Nov 24, 2008 | 06:54 AM
FLOW1's Avatar
Once the OP gives me the ok to see if they fit for our cars 08+ lancers then this will be my next mod since it isn't that expensive.
Old Nov 24, 2008 | 08:46 PM
br00t4l Evo's Avatar
not exactly what id spend my money on but looks clean
Old Nov 25, 2008 | 07:43 AM
ThanatosG's Avatar
I like this mod, but I have a question how does the hood feel when shutting? does it feel like its binding at all? or hard to shut?
Old Nov 25, 2008 | 09:38 PM
Rexpeed's Avatar
hopefully the OP can chime in
Old Nov 26, 2008 | 02:07 PM
EvoXstylin's Avatar
Those look great, I'll have to get them sometime.
Old Nov 26, 2008 | 07:07 PM
saulbyu's Avatar
It's easier to close, you just drop it half way down and the dampers close it for you. When you first start to close the hood from the top, I've gone real slow to start compressing the dampers, once you get them going it's easy to close.
Opening it is different. You have to be careful or the hood will "shoot up". I don't know if it's because the hood is so light, but you have to grab the hood until the dampers fully open or the hood will open very fast until the dampers stop it.
I'll have a definite answer on the lancer fitment later on tonight.
Old Nov 26, 2008 | 08:22 PM
ablaze's Avatar
so just to clarify, this isn't like the stock hood pole where you have to unhook from it's holder, lift hood, then "hook" into the bonnet hole again? ie. it's just a simple open-close affair without having to touch the dampers any more? ie. no hook-unhook or anything of the sort?
Old Nov 26, 2008 | 10:19 PM
Rexpeed's Avatar
stock hood pole is no longer needed just lift the hood and the dampers will support the hood one hand operation
