Rexpeed Evo X Hood Dampers
Old Nov 26, 2008 | 10:23 PM
  #31
saulbyu's Avatar
Originally Posted by ablaze
so just to clarify, this isn't like the stock hood pole where you have to unhook from it's holder, lift hood, then "hook" into the bonnet hole again? ie. it's just a simple open-close affair without having to touch the dampers any more? ie. no hook-unhook or anything of the sort?
That is correct. No need to hook or unhook anything. You open the hood from inside the car, get out stand infront of re car stick your finger between the partially opened hood, release the latch and your done. The dampers hold the hood open. When you need to close it you just pull the hood down and let it close itself with gravity. Once you install the hood dampers you don't have to touch them again.
Old Nov 26, 2008 | 10:33 PM
  #32
ablaze's Avatar
fantastic! I'm getting mine!
Old Nov 26, 2008 | 11:46 PM
  #33
Nathan0490's Avatar
Confirmation that these are compatible with the 08-09 Lancers?
Old Nov 27, 2008 | 01:58 PM
  #34
saulbyu's Avatar
After looking at a Lancer and comparing it to the Evo the Hood dampers will fit. The mounting points on both vehicles look exactly the same so you shouldn’t have any problems installing them.
Old Nov 27, 2008 | 06:56 PM
  #35
Rexpeed's Avatar
thanks for the clarification
Old Nov 27, 2008 | 10:26 PM
  #36
NateDaJew's Avatar
Are they heavy? Bump for Rexspeed.
Old Nov 28, 2008 | 02:14 AM
  #37
stevo611's Avatar
I just got the Rexpeed Evo x hood dampers and they are awesome! Shipping was supper fast as always, less than a week. Installation time is no more than 10 minutes. All you need to install them is a 10mm and a 12mm. All the hardware is included and it’s a pretty straight forward process, but don’t worry it comes with instructions. If you want to get rid of the “rod” that holds your hood open, this is the way to go. They are real carbon fiber and look amazing in person, the pictures never do carbon fiber justice. The fitment is great and I had no problems opening or closing my hood. This is how the Evo should have come from the factory.
Here are some installed pics let me know what you guys think.
BEFORE
AFTER
damn, that is really beautiful.
Old Nov 28, 2008 | 09:37 AM
  #38
saulbyu's Avatar
They are not heavy at all.
For the people that don't like the silver washer and gold screw you can always paint them with flat black paint, that's what I did and they look even better!
Old Nov 28, 2008 | 09:41 AM
  #39
jd888jd's Avatar
I got a SEIBON hood, I would assume this would not have any fitment issues?
Old Nov 28, 2008 | 10:06 AM
  #40
singo's Avatar
Definately Im getting one
Old Nov 30, 2008 | 02:42 AM
  #41
Rexpeed's Avatar
If you look closely at the install pics the mounting locations are not on the hood itself so they will fit any aftermarket carbon hoods.
Thanks,
Derek
Old Nov 30, 2008 | 11:27 AM
  #42
Yhperformance's Avatar
Smile
im definitly getting them.
Old Nov 30, 2008 | 01:49 PM
  #43
eyekyu's Avatar
great mod! def a buy in the coming weeks
Old Nov 30, 2008 | 10:48 PM
  #44
ThanatosG's Avatar
Any warranty on the dampers themselves? Also what would replacement dampers cost incase there is no warranty? If one should break that is.
Thank you, product looks great. Sorry im picky about what I buy ha...
Old Dec 1, 2008 | 10:25 PM
  #45
Rexpeed's Avatar
We havent had one single problem with these dampers. They are the same as our evo 8 dampers so they will last a long time. If you run into any issues ill take care of it
Regards,
Derek
