Modified Bi-Xenon Projector Headlights
Old Feb 25, 2010 | 12:40 PM
  #31
iEvoVII's Avatar
Hey tephra,
clear your EvoOZ and EvoM inboxs. Cant send a PM to you
Old Feb 25, 2010 | 12:56 PM
  #32
underworldfury's Avatar
Originally Posted by yahu
I think there is someone that does this as a business on here. Unfortunately the IX housing doesn't hold the FX without major modification, as far as I know.
i remember that linke also.
https://www.evolutionm.net/forums/ev...vo-ix-gsr.html
https://www.evolutionm.net/forums/ev...-pictures.html
but i think what iEvoVII does looks alot better myself.
Old Feb 25, 2010 | 01:02 PM
  #33
Harro's Avatar
Thanks for the high res! Nice work on those projectors as well.
Old Feb 25, 2010 | 01:20 PM
  #34
iEvoVII's Avatar
Thanks dude
Oh yeah, I remember those threads... TSX projectors produce much better results than CT9A projectors. The only knit picking I have is that TSX projectors have 2.5" lenses while CT9A ones are 3". They sort of look too small for the low beam housing coz you can see the gap around the projectors...
Old Feb 25, 2010 | 01:55 PM
  #35
tephra's Avatar
Originally Posted by iEvoVII
Hey tephra,
just email me
<myforumname> @ gmail.com
i dont go on evooz anymore
Old Feb 25, 2010 | 02:13 PM
  #36
evolv's Avatar
Lots of people would pay for these espeically those with GSRs, someone start selling it please
Old Feb 25, 2010 | 06:09 PM
  #37
Dr.gts's Avatar
very nice work! very very clean which projector did you use?
Old Feb 26, 2010 | 02:05 AM
  #38
yahu's Avatar
Pix of FX35 projectors in an VIIIMR housing:
http://i527.photobucket.com/albums/c...eadlights8.jpg
http://i527.photobucket.com/albums/c...eadlights9.jpg
Extracted from my thread:
https://www.evolutionm.net/forums/ev...g-edition.html
If the projector is trimmed to bare minimum, it will fit. I have grown wiser since fitting these. If I could it again, id do it differently and smarter
In a sense I will coz I still have to do the LHS.
Ill send you a PM on EvoOZ
I must be remembering wrong. Maybe it was the sheer cost of having that person do the FX35 lights that turned me off to them. It'd be nice to have bi-xenon though.
Old Feb 26, 2010 | 08:45 AM
  #39
kamote24's Avatar
NIce..
Old Feb 26, 2010 | 06:12 PM
  #40
iEvoVII's Avatar
I used the OEM CZ4A Bi-Xenon projector which is made by: HELLA
They also make the same projectors for high end vehicles:
- Mercedes E55
- BMW E60 M5's
Next time youre at the lights beside an E60 M5, wind the window down and start conversation. Tell the driver that yous are running the same projectors. When the lights go green smoke him off the line
Old Apr 27, 2010 | 11:31 AM
  #41
fattytoofat's Avatar
nice and clean...good job
Old Apr 28, 2010 | 01:26 AM
  #42
MOB EVO X's Avatar
Wow!! How much would this cost? I really want it!!
Old Apr 28, 2010 | 08:05 PM
  #43
pghdsm's Avatar
Double post
Old Apr 28, 2010 | 08:06 PM
  #44
pghdsm's Avatar
Are these installed in the standard OEM reflector housing? How did you modify it if so and did you simply dremel to retrofit and paint it black? I've found the e55 hella bi-xenon projectors themselves on theretrofitsource.com What all would be required (i.e. projectors, ballasts, shrouds, bulbs, etc). Any help would be GREATLY appreciated. If I can make do it yourself HIDs in my GSR for sub$500 im all for it! Props to all you guys for intuitiveness.
~ Brett
Old Apr 29, 2010 | 12:03 AM
  #45
iEvoVII's Avatar
hey pqhdsm,
- Yes, installed in the DRL housing. housing is no longer operational
- Yes, used a dremel to retrofit the 2nd projector then painted everything black.
- parts needed are:
* SSS headlights
* 2nd projector
* shroud
* HID kit (if your HLs dont already come with them)
Sounds like you have a a GSR with non-SSS HLs.... This is a different kettle of fish which will require more work. In the end its not gonna look the same as a SSS headlight
