THE OFFICIAL : Roof Rack Thread
Old Jul 30, 2012 | 06:05 AM
SavageGSR's Avatar
I'm looking to get a roof rack to transport two of the four tires i use for autox, anyone have any recommendations or tips to do not do... I don't know anything about roof racks...
Old Jul 30, 2012 | 07:29 AM
DagYo's Avatar
You'd probably need some sort of basket like these http://www.yakima.com/shop/cargo/gear-baskets
and this http://www.yakima.com/shop/cargo/gea...e-tire-carrier
Still not sure if you could fit four wheels up there though.
I believe each crossbar has a 100 lb weight limit as well.
Old Jul 30, 2012 | 08:23 AM
SavageGSR's Avatar
Awesome thanks for the links... I'd probably only need to fit two of the four tires up top, other two in side the car...am i reading what you're saying correctly by thinking that seeing as there are two bars, then the total weight would be 200 pounds on the basket?
Old Jul 30, 2012 | 08:32 AM
SavageGSR's Avatar
just looked up the specs / instructions on the basket... its 140 lbs http://assets.yakima.com/resource/pr...e/instructions
Old Jul 30, 2012 | 08:43 AM
SavageGSR's Avatar
Unsure which base bar set i'd need...or what the advantages are, looks like most rock the Q bar. I'd like the racks to be easily removable, obviously don't want em on there except to transport the wheels.
Old Jul 30, 2012 | 01:51 PM
bajk's Avatar
and two more pictures
Old Jul 31, 2012 | 02:57 AM
MRevo9's Avatar
Old Jul 31, 2012 | 05:29 AM
SavageGSR's Avatar
any tips / input on which base bar set to buy? most people are going with the Q-bars, other than price what else is beneficial or not about this set over the other whisper sets...?
Old Jul 31, 2012 | 05:46 AM
DagYo's Avatar
Get the q towers with the round crossbars. I had that set up on my civic and now on the evo I only had to replace two brackets to convert everything over.
Also, if you value your sanity, get the fairing. Mine was headache inducing loud before I installed it.
Old Jul 31, 2012 | 07:25 AM
Old Eagle's Avatar
Do you use the brackets called out for the base Lancer? I already have all the set up from an previous car. Can you show a close up of how it attaches to the roof? Thanks.
Old Jul 31, 2012 | 07:46 AM
SavageGSR's Avatar
Whats the benefit of the Q-bars though, just money, and universal attachment? whats the benefit to the other bars?
Old Jul 31, 2012 | 08:34 AM
DagYo's Avatar
Yeah, it's universal and the cheapest option. After the initial assembly two people can have the rack on and off in under 5 minutes.
To be honest, the whisbar wasn't available when I bought mine. It does seem to be much sleeker, albeit, more expensive. You may want to ask around and see how people like it.
Old Jul 31, 2012 | 08:37 AM
DagYo's Avatar
It's currently off the car now, but if you look on Yakima's rack builder it will tell you which clips you need. The Evo calls for Q99 clips front and back. My Civic used Q99 clips in the rear and different clips in the front, so those had to be replaced.
The clips are what are going in the door jambs. They are specific to the car the rest is universal.
Here's a pic on the Civic
THE OFFICIAL : Roof Rack Thread-zpizhl.jpg
Old Jul 31, 2012 | 08:40 AM
DagYo's Avatar
You went to the mountains with no bikes? :P
Old Jul 31, 2012 | 09:20 AM
Under_Pressure's Avatar
What rack is this and how is it mounted?? Did you drill tru the roof????
