rexpeed evo mr lips?
Old Feb 3, 2013 | 05:03 PM
DaveEvo91's Avatar
Which one of the front lips from rexpeed will fit the MR touring?? Do these bolt up to factory front chin, and are they pre drilled?? Thanks!!!
Old Feb 3, 2013 | 10:03 PM
R Lar's Avatar
All of them?
Old Feb 4, 2013 | 08:51 AM
josecruz's Avatar
you sound like you have the aero kit? if you have the aero kit you would not be able to put any lips in..unless your going to run the apr splitter.
Old Feb 4, 2013 | 08:54 AM
DaveEvo91's Avatar
I do. Which splitter??
Old Feb 4, 2013 | 09:08 AM
josecruz's Avatar
http://www.advancespeedshop.com/imag...volution-x.jpg
dont know how to post it as a photo but yea, you wont be able to install any add on lips on the aero kit with anything rexpeed. you can get the side skirt extensions i would presume tho.
Old Feb 4, 2013 | 09:27 AM
DaveEvo91's Avatar
Do those steel rods need to be used or no?? I don't mind drilling underneath.
Old Feb 4, 2013 | 09:34 AM
josecruz's Avatar
i think its optional, please someone correct me if im wrong. but you dont have to drill anything anyway, the bolts are screwed on where the cooler sits. so no new holes in there.
Old Feb 4, 2013 | 09:39 AM
ikt's Avatar
ikt
the rods lift the "chin" of the thing up a little bit more than it would normally sit. You should use them.
APR is much higher quality than rexpeed too. I do carbon repairs, and APR is very high quality stuff, I've actually been able to grind out cracks and refinish some of their stuff without any problems.
Old Feb 4, 2013 | 09:41 AM
DaveEvo91's Avatar
Any other front CF lips that would fit my aero kit for like 500-600??
Old Feb 4, 2013 | 11:06 AM
nonocei's Avatar
You would have to remove your oem front lip to install an aftermarket carbon one. You can't really have two front lips on. I would recommend the JUN carbon front lip.
Edit- saw the price range and JUN is a bit more expensive than that... not by much though.
DaltonD19
Nov 13, 2016 09:02 AM
jaime8754
Jan 30, 2016 10:35 PM
Evol Darwin
09+ Ralliart Show and Shine
11
Jun 12, 2015 03:22 PM
HPEVOX
Evo X How Tos / Installations
Jun 5, 2010 12:14 AM
The hundreds.
Oct 30, 2008 11:17 AM
