2min Away ordering a Vortex Generator.. Help?
Old Jul 21, 2014 | 03:28 PM
ikt's Avatar
ikt
Originally Posted by TxFAkuma
Does anyone have any idea what kind of tool i should use to shave this a little so it fits around the antenna? Any advice would be great appreciated. Should i just use a file? Sand paper? how did everyone else shave this so it fits?
it should fit theoretically...
here's one I did for a customer that I actually had to ADD to it
are the edges around the antenna base rolled or flat? Do you have any experience with bodywork?
Old Jul 21, 2014 | 04:05 PM
TxFAkuma's Avatar
I have no experience with body work. It just doesn't slide up towards the roof more because the antenna is in the way. So i need to shave it a little. As of now the VG would sit more on the rear windshield rather than the roof.
Old Jul 21, 2014 | 04:08 PM
spiniker's Avatar
File, Dremel, whatever gets the job done for you. Cheers from MN
Old Jul 21, 2014 | 04:20 PM
ikt's Avatar
ikt
Hand sand or microfile, or both. I wouldn't use a dremel, rotary tools remove a lot of material really fast. On carbon, best to tape it, then use sandpaper with blocks unless you have a DA or variable speed grinder.
One the scale of carbon I make/fix that's nothing, if you want to mark where it needs cut and send it in I'll do it for you. i won't charge you anything but you gotta pay for shipping
Rexpeed
EvoX 'For Sale' Exterior Styling
487
Mar 21, 2016 06:21 PM
steve0677
Jul 9, 2015 05:39 PM
AGinHD
Apr 15, 2013 12:10 AM
Lostfate
Mar 11, 2013 01:27 AM
axtran
Jul 16, 2010 04:56 PM
