Quote:
Thanks.
Did you get a response on this? I'm on the same boat with this as well...Originally Posted by Zero115
Hey guys. I got a pair of these last week that come with the red demon eye DRL built in. Does anyone know which wires inside of the headlight power these? I don't like that they turn on with the white DRL's all the time, I know people that have gotten tickets for it in my area and want to run them to their own switch. I could take a guess and just start snipping wires, but I'd really rather not start cutting blind if I can help it.Thanks.
Quote:
PS, @USCGSAM I am cheaper than amazon
Originally Posted by animalpak
Thanks!PS, @USCGSAM I am cheaper than amazon
what size are the led bulbs on the demon eye?
Quote:
you guys are going to actually open up the back & trace the wires. I know for a fact the DRL are the white & black wires inside. trying to go straight from the harness is no help because everything is spliced together coming from the harness, from what i rememberOriginally Posted by Tsane
Just got these and had the factory hid I don’t have the demon eye what size bulb u guys using ?????
ok so finally drove at night last night after the install and the beam on this lights are all over the place i just tried to balance the lights and where the adjustment screws are there just spinning the beams aren't moving FML anyone else have an issue with these ?
Quote:
They move only a couple of degrees with each turn, there is also a "min and max" point where they will no longer go higher or lower and just spin. If you have reached that point, turn it the other direction. Be sure you are on level ground and point the lights up against a flat wall with your car parked perpendicular to it. IIRC the headlight bulbs are h7. Originally Posted by 1012Xmr
Quote:
thanks 👍🏻👍🏻👍🏻
I love how these change the whole look of the car. I brought the regular ones without the demon eye. Might actually cop some demon eyes later
