Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Ride height difference in one corner with coilovers
Old Jul 3, 2016, 04:52 PM
Metal's Avatar
Hey guys,
I had the Ohlins Road & Track coilovers installed last week and noticed that the ride height was different on the front passenger corner, about 1/4" higher. I took the wheels off and measured the front coilovers, both had the same spring preload and ride height settings. Is this normal? Or should the front left and front right have the same ride height if the coilovers are set the same?
Thanks!
- M
Old Jul 3, 2016, 06:29 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Ride height variance is normal since you will have weight variance at each corner. Either have it corner balanced (after which you'll still have some ride height variance, although less noticeable). Or you can make the car sit level by adjusting the ride height portion of coilover.
I would, personally, get it corner balanced. You spent good money on the Ohlins, get the most performance out of them as possible..
CrackerJackToy
Mar 24, 2017 07:24 PM
sgevotx
17
Jun 7, 2006 08:30 PM
Yodobashi
Apr 25, 2005 07:23 AM
forum04pl
Mar 26, 2005 09:38 PM
Quick Reply: Ride height difference in one corner with coilovers
