tire rubbing question
I recently installed my Ohlins R&T along with 18x9.5 et 22 ZE40s with 265/35/18 Michelin Pilot Super Sports. I got the ride height to where I want it to be and for some reason I am getting a slight rub in the right rear only. All of my measurements are same on both rear coilovers. It seems to be a very random rub as well. I have driven around on bumpy roads, etc and do not hear the rubbing at all. The car has been aligned at -1.5 on both sides. I am running the dampering setting at 7 clicks from full stiff. Any input would be appreciated.
There is a mounting tab where the rear bumper cover connects to the body that is a common place for rubbing. pull the fender liner back and remove the bolt. Then you can tap the corner up slightly to give you some clearance and use a zip tie to secure it back.
urbanknight
41
Jan 11, 2014 02:58 PM
gabdala
12
Mar 31, 2004 06:58 PM
