Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Coilover Install Cost...
Old Oct 5, 2008 | 11:38 PM
donny_b's Avatar
Hey Guys....I was just wondering what it the average cost to install Coilovers on GSR or MR. The local speed shop what to charge me $400. Is that reasonable? Thanks......db
Old Oct 5, 2008 | 11:55 PM
tripperfx3's Avatar
Thats not bad. Especially if they're going to corner weight them and the such, but I doubt they will for that price. Regardless they can be a pain in the **** to get each corner set at the proper height.
It's really quite an easy install though and I'd recommend you doing the install yourself and taking it to a good shop to get set up and corner balanced.
Old Oct 6, 2008 | 12:45 AM
sgvTBevo's Avatar
Install and setup up to your liking? 400 for just an install alone is a rip. You can easily install it w/help from a friend in probably 2 hrs give or take. Go to any tire or suspension shop and have it aligned after.
Old Oct 6, 2008 | 01:06 AM
donny_b's Avatar
That's what I thought...They put coilovers on my 350Z for $275. I was not there to take the car. My son drove it over there. He said it is more difficult because of the rear coils are hard to replace. I'll have to find a DIY and give it a go myself....thx guys...db
Old Oct 7, 2008 | 12:14 PM
EvolvedVIII's Avatar
For a stright install Robispec charges like $100. To install coils, alignment, and fender rolling I was quoted $580.
Old Oct 7, 2008 | 12:29 PM
08EvoXGSR's Avatar
Installed BC's on mine in 3 hours (total time incld jacking ) and had the ride height by the next morn (its annoying to set, let it settle, ect, but worth it imho). I'd say give it a whirl at home in the garage before someone does something you wont like-and you have to give them $ for it....
Old Oct 7, 2008 | 07:22 PM
How was the install on the rear?
Old Oct 7, 2008 | 07:36 PM
Evolessfornow's Avatar
Install them yourself. It's free, you learn something, and you get the satisfaction of doing an install on your own.
Old Oct 7, 2008 | 07:47 PM
Robevo RS's Avatar
you need a wheel alignment after that, so include that one in the install cost too.
If you never did anything like this before, DO NOT DO IT YOURSELF.
Leave it for some reputable suspension shop or some where, where they do wheel aligmnets also. SO it can be done at a same time. Maybe will be cheaper that way the whole process.
Old Oct 7, 2008 | 09:20 PM
galant350z's Avatar
400 is a rip off, 250 - 300MAX is reasonable, + 100 for alightment
Old Oct 9, 2008 | 12:42 AM
fastkevin's Avatar
Darin at West End Alignment (one of the best) charges $150 for CO installs. IIRC, the install, alignment, and corner balance is $375.
Old Oct 9, 2008 | 01:45 AM
Jolly Roger's Avatar
def try the install your self its not that hard and then you can take it to a tire shop give them the spec's you want and they'll do an alignment for prb under 100 bucks
Old Oct 9, 2008 | 02:21 AM
WWEVO206's Avatar
DIY. It's not hard.
Old Oct 9, 2008 | 03:14 AM
DRAGHICI's Avatar
the correct way to do it is to corner weigh the car, this alone will make the coilover worth it, are you going for correct ride or just looks? because if its looks just get springs, if your looking for a correct ride YOU MUST CORNER WEIGH, also don't go cheap, the good ones start at 2k and up.
what are you really looking to do with your car?
Note: I'm not an expert, but I listen to experts for stuff like this.
Old Nov 16, 2009 | 11:33 AM
CmakEVOX's Avatar
i got quoted 4 hours for labor to install coilovers on the X. is that average time for a shop to install coilovers? For those who paid a ship to do it....how much time did they charge you?
