Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Wheel Offset Fitment Chart
Old Apr 8, 2011 | 02:13 PM
  #46
journeymansteve's Avatar
Originally Posted by journeymansteve
Since this is the "Fitment" thread, I wanted to pose a question for how can you see if your particular wheel is "too wide"? I bought an off brand, JWL cert, that are supposedly 18x9.5 ET25. I have not mounted tires on these -- dealer and MFR warnings everywhere that once I mount, I own. These also come in ET38.
When I have them on the car, the outer lip of the rim is directly below the fenders. They don't have any overlap with the fender. On the inside, they have a thumb-width, guessing about 15-16mm. I am nervous about going 13mm towards the inside because I do set my camber to the factory 1-2deg negative setting for spirited driving (HPDE, etc)
How can you tell you have good fitment on the outside without putting weight on the car?
Update: Best way, use the stockers with ride height (weight) and simply measure and trust. Back-spacing measurements were exactly what they should be. Having the stock offset for so long sort of trained me to get used to a sunken look. I love the totally flush offset, very very aggressive for the part of the country I live in. A few lowered cars, but not many that push the offset to the limit like you can with an Evo's stock suspension.
Old Apr 16, 2011 | 05:14 AM
  #47
thrlskr's Avatar
I have 18x9.5 +30 wheels and swifts. Do you think 275 35 18 tires will rub?
Old May 28, 2011 | 09:10 AM
  #48
visieon's Avatar
Fronts will be fine, roll the rear fenders to be safe..
Old Jun 6, 2011 | 01:09 PM
  #49
popdakebin's Avatar
Need help. About to get 18x9 +20 wheels. Need to know if Hankook v12 with size 255/40/18 will work.
Old Jun 6, 2011 | 01:33 PM
  #50
Sev's Avatar
Sev
Eibach Pro Kit Springs
18x9.5 +22 Wheel Size
265/35/18 Tire Size
I was looking for RPF1's but all I can find is +15, would I rub on +15's?
Old Jun 6, 2011 | 01:37 PM
  #51
trick3d's Avatar
265/35/18 Tire Size
What I've read is that with the RPF1 at +15 you need to roll your rears and apply some decent camber. Not sure though since the drop is minimal, but those springs are soft.
Old Jun 6, 2011 | 02:13 PM
  #52
Sev's Avatar
Sev
Sounds good. I'll wait for a second opinion too. As for a +22 offset, those should work well w/o rolling I presume?
Old Jun 6, 2011 | 02:59 PM
  #53
trick3d's Avatar
^ yes but for some reason im not sure if the RPF1 design clears the brembos at +22. you might need to run a spacer. Wait for somebody else to chime in.
Old Aug 21, 2011 | 01:13 PM
  #54
smgevo's Avatar
No. That is the perfect set up especially for the stock suspension and ride height. I have tracked them in your wheel and tire size without any issues using the Nitto NT01.
Old Oct 1, 2011 | 06:14 AM
  #55
pHi's Avatar
pHi
I'm thinking about buying Volk GT-C with Wheels specs: 19x8.5 +27et & 19x9.5 +24 (5x114.3)
Do you think it will fit on without spacer ?
Old Oct 6, 2011 | 09:22 AM
  #56
Slay0r's Avatar
ok, i went through the whole thread, and i didnt see this size/ question asked, so heres mine
Im interested in getting Drag DR 31 wheels. They are Work/Rota knock offs (big for the subie guys)
the size im interested in getting is 18x9" +15et. I'd like to make sure these clear the caliper.
As far as tires, i'd be looking at 255/35 lowered on Cobb's coils (with future plans of BC coilovers)
thanks for input/advice in advance
Old Oct 19, 2011 | 02:46 PM
  #57
WWGSR11's Avatar
Will a 18x8 wheel with 40 offset fit 2011 evo x with 245/40/18 blizzak lm-60 tires?
Old Nov 22, 2011 | 08:01 PM
  #58
RavSpec's Avatar
Too narrow on the size and too high on the offset.
Old Dec 31, 2011 | 08:35 PM
  #59
gotmangoo's Avatar
Hey I tried searching online to answer my questions but was found with no luck. I have wheel size of 18×9 30 offset and am clueless of what tire size to get to fit in with the h&r sport springs I have. I don't want the tires to rub... I found the ideal size to be 255/35/18. Would this be bigger than 245/40/18(stock tire size?)? If I could get more tread for a bigger tire, that'll be nice but I don't want it to rub either.
Should I go with 255/35/18 or 245/35/18 or 245/40/18?
Sorry if this has been covered before but I couldn't find an answer that matches my wheel size and the springs I have. Thanks
Old Jan 4, 2012 | 12:48 PM
  #60
RavSpec's Avatar
EVO X ...
18x9 +30 is conservative fits. 255/35 will be good.
