Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Wheel Offset Fitment Chart
Old Oct 6, 2014 | 09:05 AM
  #76
LB_Reddy's Avatar
Originally Posted by JDEve
Question.... I have been eyeballing Enkei RPF1's, will the 18x9.5 (or 10) 30mm offset fit the Evo X without any suspension work? I will probably have to roll fenders right?
I dont think u have to roll fenders unless u go over 10+ wider.Im sticking to 18x7.5 on stock tires for now that will fit good.not sure what my offset is,for most road cars should be between 10-50 either - /+/0 offset.
Old Oct 6, 2014 | 11:51 PM
  #77
PiratGT's Avatar
18x9.5 with et+15 and tires 265/35/18 will rub on X on stock suspension without rolling rear fenders??
Old Oct 8, 2014 | 02:25 PM
  #78
elkazX's Avatar
Im planning on buying gram light 57c6 rims..will a +12 offset fit? they are 18x9.5 and will most likely be running a 255 size tire. I have 18x9.5 rpf1's now with a +15 offset and they clear but just wanna check before i buy the gram lights.
Old Oct 9, 2014 | 03:06 AM
  #79
PiratGT's Avatar
With these parameters you will need to roll fenders and put wheels with -1 or -2 dergrees camber
Old Oct 9, 2014 | 07:38 AM
  #80
RavSpec's Avatar
yes will clear caliper. Installed pics
https://www.flickr.com/photos/lcrazy...463208/sizes/l
Old Oct 9, 2014 | 03:50 PM
  #81
elkazX's Avatar
So I'm guessing that how all wheels with these exact specs will be right? Like if i wanted to get work emotion D9R's that are 18x9.5 +12 offset i would have to roll fenders and they would still clear the brembos correct?
Old Oct 10, 2014 | 03:14 AM
  #82
PiratGT's Avatar
Sounds correct.
My friend put TE37 18x9.5 et12 with 265/35/18 tires and he was rolling fenders and done -2 deg fwd and -1.5 rear
Old Nov 16, 2014 | 02:12 AM
  #83
HollywoodTatted's Avatar
20" rim fitment
I want an actual answer and don't want to hear opinions... Does anyone know if a 20x11 wheel would fit on my car? In the future for suspension I am gonna be on air... Need help!!
Old Dec 13, 2014 | 04:27 PM
  #84
jsaviour84's Avatar
WEDSSPORT TC105N 5X114.3 18 x 9.5 +10 clear brembos?
Old Dec 16, 2014 | 11:31 AM
  #85
NEpsiOver21's Avatar
Hollywood, i believe only 22's would work for your case.
Old Dec 18, 2014 | 04:49 PM
  #86
elkazX's Avatar
wanting to get myself enkei nto3s, 18x9.5 +27 but read you will need spacers to clear front brembos? what size spacer and anyone have any pictures of this setup with the spacers.
Old Dec 18, 2014 | 05:53 PM
  #87
elkazX's Avatar
or also looking into te37sl's. 18x10.5 +22 most likely. with a 265-35 tire, i will probably have to roll rear fenders a little bit and maybe some camber, correct? or should i do a 275-35 tire?
Old Dec 19, 2014 | 01:26 AM
  #88
Aashenfox's Avatar
For the NT03s, better to go for the 9.5+15, same as your current RPF1 fitment, I assume you've already rolled the rear for those to fit nicely...
Curious why you're mentioning two options, of which the first is notably less aggressive than your current setup and another that will be noticeably more aggressive...
10.5 +22s will also fit where a 9.5 +15 fitted (only 5mm more aggressive) with the same tires as the 9.5s. Depending what you're lowered on will make the choice of tires for you. If you're low, that extra 5mm may give you an issue, if I were you I'd go to a local friendly tire place and do some test fitting.
Old Dec 19, 2014 | 01:38 PM
  #89
elkazX's Avatar
the nto3's do not have a +15 option. its 18x9.5 +25 or 18x10.5 +30, ive kind of thrown out the nt03s as to that exact reason. I want an aggresive setup which is why im looking at the te37s.
Old Mar 11, 2015 | 05:18 PM
  #90
xTHExEngineer's Avatar
Question important Question
okay so if the 18 10.50 et38 is +25/+25
then is it safe to say any rims ET on 18 9.5 that places the rims 0/0 to +25/+25 are safe to use??
