Help!! Help!! Service light w/new Wheel
Has anyone else had this problem, its not from the engine, car is fairly still new!! any thoughts or suggestion or if this is a quick fix that the dealer can handle, help!!
Thanks, any input is greatly appreciated, getting these new wheels on has been such a pain this weekend, wheels are CE28n 19x10.5 +22 275/35 19.. dont know whats going on, and im still having minor rub issues
Thanks again!!
Thanks again!!
Man, this sucks, now i have to deal with mitsu.. What could it be, speed sensor??? or something??? Any clue guys, i know im not the only one that has an aggressive setup..
^^^ TPMS, i have a regular GSR SSS, i dont think i have that do I???? thanks for the input though
Last edited by Milf_Hunter_V; Apr 13, 2009 at 11:49 PM. Reason: appreciation of input
TPMS - Tire Pressure Monitor Sensors....you have them....I have them too. I haven't changed my wheels out yet though because I'm deployed.
I would check the Aggressive wheel thread up here for Evo Xs to get an idea of what you could do to stop the rubbing. As for the service light, I don't know....did you swap the sensors out of your old wheels?
If there are no sensors for the ecu to read then you would probably get that service light. I heard new sensors cost about $70 a piece but I would check with the dealership or swap the ones out with your old wheels.
I don't know what they look like - they could be in the valves or a ring around the wheel. If I were you I would go to the parts department (Mitsubishi) and see if you can get an idea of what they look like (ask them to give you a picture) and how much they cost. Maybe you can find them some where else cheap if they are expensive.....
It's your sensors man. You could go to Discount Tire like I did, plunk down what they want for them and have them installed, and then hit up a Mitsu dealer and have them charge you around $100, give or take a bit, and have your car recalibrated to them. Or you could go without the sensors like a lot of people do on here and turn off the warning light everytime to lose traction, open a car door, or start your car.
