Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Straight answer...PLEASE!
Old May 4, 2009 | 10:43 AM
bryanole27's Avatar
Simple question...but apparently a complicated answer...
Work Emotion CR-KAI 18 x 9.5 +20mm w/ Eibach springs
Will they rub or not? That simple...either they will or they won't.
I'm even having vendors change there answers on me...
Can I please get a straight answer for the love of God?
Thank you.
/rant
Old May 4, 2009 | 10:55 AM
goofygrin's Avatar
What tires?
They'll clear the brakes fine, but if you go with a 275 wide tire they will rub (so go 265).
Old May 4, 2009 | 11:04 AM
bryanole27's Avatar
Originally Posted by goofygrin
What tires?
Thank you! For now...stock tires until I need to replace...then 265s.
I just had a vendor tell me that the +20 will clear the fronts, but have to roll fenders, and for the rears I need +30 and have to roll fenders. Is that completely false?
Old May 4, 2009 | 11:07 AM
goofygrin's Avatar
Did they think you had an 8/9? On the X there's a good amount of room but +20 is aggressive on an 8/9. Again, the standard 18x9.5 +22 with 265 tires doesn't require any fender work. I think 2mm will likely be just fine.
Old May 4, 2009 | 11:08 AM
bryanole27's Avatar
Perhaps he thinks I have a 9...but I have talked wheels with him before...so who knows.
Again...thank you for the answer.
Old May 4, 2009 | 11:17 AM
EvoX2NR's Avatar
bryan... fyi, I am running a 18x9.5 +22 and on stock tire sizing it doesn't rub (at about the same height as you). If you go to 265's it will most likely need a fender roll.
Old May 4, 2009 | 11:18 AM
bryanole27's Avatar
Thanks Chris!
Old May 4, 2009 | 11:20 AM
EvoX2NR's Avatar
No problem!
