Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Replacing the Ball Joint boot!
Old Oct 16, 2009 | 05:01 AM
j_barcarse's Avatar
Unhappy Replacing the Ball Joint boot!
Is the Ball joint boot replaceable??? I didnt even get a chance to get a good look at it. But I Know for sure it's ripped. The mechanical function is still good. Im sure installing it isnt hard. Is there a specific tool used?? or is it one of those things where you just put it on and put the rest of the parts back on and it will install itself?? or is it easy enouigh to a point where you can just slide it in??? I just usually replace the whole thing butin this case, working with an aluminum control arm is very risky.
Old Apr 28, 2010 | 08:00 AM
B-rent's Avatar
just take your wheel off and remove the CV boot. Then attempt to dismantle the ball joint, If you cannot then you know your answer. If you can just take parts needing replacing to the dealership and order and OEM replacement. problem solved
Old Apr 28, 2010 | 08:43 AM
EvoIXMR's Avatar
the Evo VIII/IX FSM talked about replacing the boot and the tool needed. Check the X FSM, I am sure its the same. If your balljoint goes out, then you have to replace arm since mitsu does not sell balljoints separately (used to sell them in DSM days). Its a freakin racket to take our money. If moog or someone else came up with a balljoint, they could make a ton esp. for people who race these cars. Some vendor should be able to pull this off too...
Old Apr 28, 2010 | 08:54 AM
goofygrin's Avatar
Install a whiteline roll center correction kit, it includes new ball joints.
If you can find the boot (ie. from someone that's installed the kit, I tossed mine unfortunately) then you just have to pull the wheel, pull a nut and bolt, pop the ball joint out, pull the boot up and off and then replace it and reverse the process to reinstall.
Or are you talking about another ball joint somewhere?
Old Apr 28, 2010 | 08:48 PM
tephra's Avatar
yeah if you cant replace the boots individually then you might as well install the whiteline roll center kit...
Old Apr 29, 2010 | 05:49 AM
EvoIXMR's Avatar
I haven't been under the X yet, is there only 1 set of balljoints on the car? I wish someone also came out with better spherical's for the suspension. Lots of the VIII/IX arms has sphericals which I have heard is bad to replace with poly bushings and I don't think anyone made any, actually! I had replace every bushing I could on my VIII with whiteline and Perrin caster (PSRS).
Old Jul 7, 2011 | 09:50 AM
j_barcarse's Avatar
I ended up ordering the ball joint boots from Mitsu and installing them when I did my clutch. Good thing my ball joints were still good lol...... and the boots been ripped for a long time hahahaa
Live4Redline
27
Apr 14, 2018 04:13 PM
aggieEVO
Sep 21, 2015 07:03 AM
xtnct
11
Jul 21, 2009 07:39 AM
Boost3dxEvO
Jul 9, 2009 07:02 PM
travelsize420
Lancer Troubleshooting
Jul 6, 2006 10:51 AM
