275 35 18 falken RT615 on 9.5 wide rim
I have searched, but found nothing. I'm after info about Falken RT615 275-35 R18 tyre. Infos about the actual width of the tyre off the rims, rolling diameter, etc. Wondering if it would look bulgy (275-35 R18 tyre on 18x9.5 +20 rim). Would it feel squishy? Or is it better to get a proper size like 265? Reason is I have found falken FK452 275-35 R18 tyre not that wide, it actually sit right on a 9.5 wide rim.
Post a photo if you have any.
thanks
thanks
A lot of people have put 275's on 9.5" wheels. And the +20 should be a perfect offset. You can search on here, and there is a thread called "Agressive wheels" or something and you can see everyone else's setup with pics and specs.
Not too many people (here in the states at least) are still using the RT-615, as there are better tires out now. Even falken has come out with a newer version of that tire - RT-615K I believe.
Here is a site I like to use to figure out offsets/tire diameter and width/etc. http://www.rimsntires.com/rt_specs.jsp
Good luck!
Good luck!
Thanks. I have been using that website for a while now. But they haven't got falken rt615 on it. Reason also for this is that there is sale here, but limited on size next to 275-35 R18 is 255-40 R18 which is a bit tall.
Mikami
Jan 20, 2016 11:19 AM
asianhommy
20
Jan 8, 2016 11:25 AM
asianhommy
Dec 2, 2015 10:47 AM
v8<turbo4
Aug 4, 2015 10:20 AM
