Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Roll center adjustment kit
Old Feb 8, 2011 | 09:55 AM
  #31
SilverBulletIX's Avatar
This is a very interesting thread. Those of you who have this product installed, please continue to post your personal experience with the kit.
I just orders the kit bc I'm installing my Spec Rs this weekend. Did I make the wrong decision, or is this wear and tear worth the short term benefit?
Old Feb 8, 2011 | 10:21 AM
  #32
oftheheavens's Avatar
Originally Posted by black95tt
I totally agree! But what better vehicle to tackle these crap snow days than an Evo? My evo X that I just bought has never seen snow. It pains me to take it through all this stuff, but whatever. What can you do?
Sorry to get OT, but seriously, I had issues with those RCA kits. I've heard that the OEM boots will work with them, but I've not actually ever seen anyone change them out. When I had problems I emailed whiteline and also started a thread some time ago and they stand behind their product, which is good. They also hooked me up when I needed a new set because I b*tched about it. But the fact remains that it's a problem, and I don't want to be replacing those every few years. I want something that will last the life of a car, as a ball joint should.
i have also heard you can replace with stock boots, i am going to do this on saturday when i install them.
Old Feb 8, 2011 | 11:11 AM
  #33
black95tt's Avatar
Be sure to update the thread when you do. Thanks.
Old Feb 8, 2011 | 11:12 AM
  #34
MarkM's Avatar
anyone know if this kit has been improved? I have 2 kits here from a group buy, one for a friend, and they are different colours and the boots are different...same part numbers!
Old Feb 9, 2011 | 11:36 AM
  #35
BPAuto's Avatar
Silver Sponsor
Hmmm...this is definitely interesting. Thinking of grabbing a set myself but would like to hear an answer to the revision/long term reports.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Feb 10, 2011 | 05:55 AM
  #36
BPauto i will take a look at the boots when i am installing, although i do plan on using the stock boots if i can figure out how to transfer them.
Old Feb 10, 2011 | 08:30 AM
  #37
MarkM's Avatar
Interesting to see which of the 2 you get, mine were bought at the same time!!
Imo the ones on the left of my pic with the crease line around the middle seem to be an older design, same design as the pic further back in this thread of cracking by black95tt, the other pic of the set which has been fine seems to be the more yellow and rounded boot in the right of my pic.........
Old Feb 10, 2011 | 08:47 AM
  #38
lakay888's Avatar
definitely reccomended, even if you say its DD car when you see that Twisty road in front of you and somebody is tailing your rear,you will have the need for speed, at that time you will be glad you made this uprade
Old Feb 10, 2011 | 12:05 PM
  #39
i got the rounder ones.
Old Feb 12, 2011 | 09:04 PM
  #40
pghdsm's Avatar
I picked my kit up around Christmas and its got the more rounded boot as well. I'm willing to bet they did change the design.
Brett
Old Feb 12, 2011 | 09:31 PM
  #41
casper980's Avatar
My X is lowered on Eibach springs. I very much want to put one of these kits on my car but I'm hesitant for this exact reason. My hesitation does not stem from hearsay either. I have personally experienced these boots ripping on TWO sets of RCA's. The boot material might stand up better in southern climates, but up here in the salt belt, the hot and cold break them down in short order. If there was a way to use the factory boots, or upgrade to something that will last, I'd be much more interested.
Whiteline stands by their product, I had one of the toe rod ends loosen and distort in the knuckle, not sure if it was caused by kissing a pole on an ice rink or it didn't get tightened down well enough or what, but I called them, in AU... they put me in touch with local distributor and they replaced it for free. Did you call them?
Old Feb 14, 2011 | 09:41 AM
  #42
black95tt's Avatar
Yes, I did contact them. You must have missed this post:
"I emailed whiteline and also started a thread some time ago and they stand behind their product, which is good. They also hooked me up when I needed a new set because I b*tched about it. But the fact remains that it's a problem, and I don't want to be replacing those every few years. I want something that will last the life of a car, as a ball joint should. "
Old Feb 14, 2011 | 04:24 PM
  #43
i installed the cobb springs and roll center adjustment.....only problem i had was that i didn't realize that the RCA ball joint had a notch in i so i ruined the bolts trying to get them back in.
the ride overall is AMAZING! this is how it should have been stock.
Old Feb 15, 2011 | 05:02 AM
  #44
black95tt's Avatar
Oh noes! Yeah, gotta watch that notch. Did you resuse the factory boots?
Old Feb 15, 2011 | 05:24 AM
  #45
no i didn't, i got the updated boots from whiteline so i figured i would give them the benifit of the doubt and use them.
Any idea if it is bad juju to have have the notch lined up? other than having to force the bolt obviously?
I got an alignment yesterday with ~-1 camber all the way around and as close to 0 toe as he could get it, and it feels so much more smooth and controlled now around turns.
