Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Roll center adjustment kit
Old Feb 3, 2011 | 12:06 PM
oftheheavens's Avatar
I am dropping my evo x on cobb springs and was wondering if it would be a good idea to get a Roll center adjustment kit.
the cobb drop i believe is 1.4/1.3
Thanks!
Old Feb 4, 2011 | 11:06 PM
pghdsm's Avatar
Thanks!
THE Whiteline Roll Centre Adjustment Kit Part # KCA395 is a great investment with any lowered vehicle as you're changing the geometry of your suspension and weight transfer distribution..
Cheers
Brett
Old Feb 5, 2011 | 12:36 AM
sosojeff's Avatar
How much do they go for?
Old Feb 5, 2011 | 12:38 AM
4G63kevin's Avatar
How necessary are they for a dd?
Old Feb 5, 2011 | 06:39 AM
Touge factory told me for DD they are not necessary
Old Feb 5, 2011 | 06:43 AM
Tuxevo's Avatar
If you bought your Evo wanting it to handle like a Subaru, then a roll center correction kit isn't necessary.
Old Feb 5, 2011 | 08:02 AM
Thanks for that amazing input lol
Old Feb 5, 2011 | 09:14 AM
jimm's Avatar
The best thing about the Evo X is it's handling stock. When you change it you have every chance of making it worse not better. Why buy a performance car and mod it to perform worse?
It is why you should buy from or at least listen to people like GT worx or Robi spec who test the cars and know the mods make the cars better. You lower the car you need to correct the geometry.
Old Feb 5, 2011 | 09:43 AM
pghdsm's Avatar
Depends - anywhere from ~$175-$190, however you're going to pay a machine shop to have the ball joints pressed from your lower control arms and the new ones pressed back in. Do NOT cheap out and try using a hammer, you're going to destroy them.
Not absolutely necessary but how many of us have "unnecessary" parts on our daily drivers/weekend track cars?
You absolutely want to talk with GTWorx or Robert Fuller of Robispec.
Here's a pdf explaining their product. http://www.whiteline.com.au/instruction/Z351_KCA395.pdf
I would highly recommend any of their products/great customer service. No I don't secretly work for them. I don't think you stated, but what exactly are your goals for the car?
Brett
Old Feb 5, 2011 | 09:45 AM
pghdsm's Avatar
You're 100% right, it's not going to handle like a Subaru, more like a go-cart!
Old Feb 5, 2011 | 02:03 PM
Awesome replies and info thanks a bunch.
I am not going to get it right away but I will get it soon. Do you need another alignment afterwards?
Old Feb 5, 2011 | 04:46 PM
Tuxevo's Avatar
I'm not sure if you needed me to speak to this. I gave a clipped answer because of the suggestion that adding a low cost mod to keep your cars performance on par is unnecessary. If you lower your car you will drop the front end roll center below the surface of the road. This will translate into additional understeer during aggressive cornering. If you've driven an STI you'd know that they are even more prone to understeer than our cars, hence the reference.
If you get your springs it would be a good experiment to drive on them for a while, get the feel of the car, then install the roll center correction kit and see if you can tell the difference.
Old Feb 5, 2011 | 05:28 PM
Awesome thanks, that is what I am going to do. I will post here in a month or so when I put it in.
Old Feb 5, 2011 | 05:58 PM
Kracka's Avatar
Not very.
Yes.
Old Feb 6, 2011 | 02:10 AM
sailorcor's Avatar
I have the kit on my car and it's solely a DD. I wouldn't say it's necessary, but i'd definitely recommend it. I could feel a difference immediately and i always say if you're going to do something you might as well do it the best you can.
