Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Offset question
Old Jul 11, 2011 | 12:04 PM
limx's Avatar
Offset question
Does the SA55M 19x9.5 with +15 offset will fit on the EVO X MR??
or go with the +24 offset??
need some help please..
Old Jul 11, 2011 | 12:12 PM
ugakirk's Avatar
Either one will look ok but the +15 will look much better. especially if you are going to lower it some..
Old Jul 11, 2011 | 12:20 PM
limx's Avatar
will it fit fine? without rolling fender and without adjust the camber..???
I read in the other forum, that +15 wont fit on EVO X, but it this true??
thnx
Old Jul 11, 2011 | 12:52 PM
MarkM's Avatar
+15 will stick out of the arches way too much, +24 is perfect imo
Old Jul 11, 2011 | 01:09 PM
Boltz.'s Avatar
FCOTM Winner
You can pretty easily do either on the X. The lower offset will require fender rolling. You may or may not need it with the +24. It depends greatly on tire size as well as that is what is actually going to rub, not the face of the wheel.
Old Jul 12, 2011 | 12:59 AM
JDMCT9MR's Avatar
I am running a 18x9.5+22 and love the look.
Old Jul 13, 2011 | 11:53 AM
Gruppe-S's Avatar
19x9.5 +24 would be a great fit.
On the +15 you will need to roll the rear unless you run something like the stock tire size..
if you do that its kid of pointless getting wider wheels lol
Old Jul 14, 2011 | 11:56 AM
limx's Avatar
thank you very much guys,
appreciate all your replies and help..
I'll go with the 19X9.5 +24 offset, when the wheel are mounted I'll post some pics..
LimX
shLa11
Nov 12, 2012 01:25 PM
thatguy5
Nov 1, 2011 08:18 PM
ElvisT
30
Aug 8, 2011 06:55 PM
sairaag
22
May 20, 2006 04:11 AM
NocturnalEVO
24
Jul 29, 2005 06:54 AM
