Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
brake bleeding issues:/
Old Aug 29, 2012 | 12:08 PM
Evolution Z's Avatar
haha yeaa, well the only reason i posted that is bc i read somewhere that if theres air in the mc, you have to bench bleed it. why wont it work if i just fill the reservoir and bleed normally? i guess thats my question
Old Aug 29, 2012 | 12:19 PM
Iowa999's Avatar
The problem comes from where the hose leaves the MC. if it doesn't leave in what is effectively the top corner, then you'll never push the air out it into the hose (and then down the line to the caliper and out). In that case, you have to take the MC off the car to get all the air out of it, unless you have a way to lift and tilt the whole car, tee hee.
Old Aug 29, 2012 | 02:11 PM
tilt it which way, you say? >.>
Old Aug 30, 2012 | 03:47 PM
should i tilt it from the rear end so that any air in the front end of the mc can escape up?
Old Aug 30, 2012 | 04:46 PM
Iowa999's Avatar
It was a joke. You can't tilt the whole car enough to bench-bleed.
Old Aug 30, 2012 | 06:44 PM
lolz- shows how much i know. guess the fluid is too viscous for a bubble to move thru it at such a low angle.
in other news: i was reading the fsm.... says to bleed the mc, all u gotta do is unscrew the two lines, plug the two outlets (with ur fingers) as if they were acting as ur bleeder screw, then just bleed it like u wuld bleed lines normally
Old Aug 30, 2012 | 06:47 PM
also, called mitsu, spoke to a service rep (now we all kno how great and reliable they are so take what u hear with a grain of salt), but i was like "shuldnt i have to bleed the mc since i let the reservoir run dry?" hes like... nawwww you shuld be fine. im like k lol.
ALSO: in the magnus cmc install... it says nothing about bleeding the mc after installation, it literally says to just "fill reservoir and bleed lines as normal" .... soooo... yea, idkkk what i should do:/
Old Aug 31, 2012 | 05:58 AM
blackgsx01's Avatar
Do your bleed in order. Make sure your bleed screws are closed. Pump your pedal till its firm. Start you car and let it idle, pump your pedal again till its firm. Bleed brakes in order again while the car is at idle. Shut off, pump again till firm, bleed one last Time in order while the car is off and go test drive
I used a motive power bleeder, but if you have some one pumping your brake pedal you will be fine. I did new Ss lines, Repainted my calipers, new rotors and pads. Had the car apart for a month doing the calipers. My master cylinder was dry for a month(other than the clutch cylinder part in the brake master cylinder) my brakes are very very firm
Old Aug 31, 2012 | 09:36 AM
what does bleeding with the car at idle do? never heard of that
also, u didnt bleed the bmc? u just filled it up and bled the lines as normal?
Old Aug 31, 2012 | 10:28 AM
Iowa999's Avatar
Having the engine on (i.e., idling) means that the brake booster will be helping you push the pedal. I prefer to bleed without the help, since the feel of the pedal is one way to know when you've succeeded.
Old Aug 31, 2012 | 05:12 PM
blackgsx01's Avatar
No I didnt bleed the master cylinder. Just filled up and bled as normal. I didn't bleed my slave cylinder neither since it is separate.
vipevo9
Aug 25, 2016 12:36 PM
przemekwid
Feb 18, 2016 07:49 PM
Marv 97
Sep 8, 2015 10:04 PM
governmule
Midwest Region
May 14, 2011 08:59 PM
EVO Rosso
Mar 6, 2011 12:08 PM
