Rear fenders rub after installing 18x9.5 +20 with 245's
https://www.evolutionm.net/forums/ev...s-go-here.html
People running 265's require fender mods in order to avoid rubbing.
It really depends on the specific tire and, also, the wheel width. And then there's the camber (especially in the rear, to stay away from the fender lip) and whether your camber bolts are flipped (which affects the clearance between the front tire/wheel and the shock). A general statement would be misleading because it would not be generally correct.
Well , i also get my Work CR Kiwami, size 18x9.5 +20 offset on my Evolution X 2013 with 245/40/18 hanokook Rs3 And after Camber in the rear , no problem at all
Camber setting
Camber setting
Camber test result
Work Kiwami 18x9.5+ 20 offset deep
Camber setting
Camber setting
Camber test result
evil03
1180
Sep 21, 2021 10:31 PM
OliveRC
Apr 2, 2017 10:48 AM
