Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Brake swap complete.
Old Oct 5, 2012 | 09:27 PM
thegoodservant's Avatar
Easiest one I've done on any car I think. Hardest part was breaking the rotors loose from the hub.
Old Oct 6, 2012 | 08:32 AM
ravenjam's Avatar
Got pics?
Old Oct 6, 2012 | 09:29 AM
TheBlade's Avatar
PB Blaster, wait 30mins, use a rubber mallet.
Old Oct 6, 2012 | 01:14 PM
Johnr352's Avatar
Brake swap? From stock to what? Or are you talking about a pad and rotor change. If the latter then yes, a 30 minute project with a little PB blaster.
Old Oct 6, 2012 | 03:43 PM
MadBoostedEvo's Avatar
What's the point of this threat? Just to say that doing a break job on an Evo is easy.............................................. .
Old Oct 6, 2012 | 03:51 PM
Yes, just pads and rotors. Just thought it would have been a little more difficult. The first rotor front drivers side,was pretty well stuck on but the others came off with just a little tap.
Old Oct 6, 2012 | 03:55 PM
TheBlade's Avatar
To make this thread useful for anyone reading....
Sometimes with rotors and drums for that matter, there is a little threaded bolt hole. It's so you can take a bolt and thread it through and it will pop the rotor/drum off if it's really rusted on there. Since brake components can get nasty-stuck from years of salted roads during the winter in some areas.
Now you know, and knowing is half the battle
GI JOE!
Old Oct 6, 2012 | 05:53 PM
acm_evo's Avatar
GI JOE!
Great tip! I remember seeing that on brake drums, and always wondered what that threaded hole was for. I wonder whether the Evo has the same arrangement on the rotors. Can anybody confirm it ? ..
Old Oct 6, 2012 | 08:24 PM
Johnr352's Avatar
Yes, confirmed. Depending, of course, on what rotors you are using.
Last edited by Johnr352; Oct 6, 2012 at 08:24 PM. Reason: Depending, of course, on what rotors you are using.
Old Oct 7, 2012 | 01:47 AM
They do have the hole. (Stock rotors) All four in fact, however when I tried using this hole the bolt simply broke off in the hole, no rotor movement. A moderate couple taps with a padded hammer easily did the trick.
EvoOtto
Oct 29, 2015 07:13 PM
reliablefr
18
Aug 30, 2012 11:46 PM
Melon
Feb 8, 2012 11:16 AM
NismoSkylineGTR
Nov 3, 2002 01:08 AM
