Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
duralast cmax pads
Old Nov 29, 2012 | 03:38 PM
gregalmighty's Avatar
duralast cmax pads
Decided to try a different pad for daily driving since the OEM pads create so much dust and are noisier than hell. I went with the duralast cmax pads AutoZone sells, after seeing quite a few positive comments about them I figured they were worth a shot.
Ive only bedded them so far, don't really have any mileage on them yet, but I was fairly impressed during the bedding process. They don't bite as hard as the OEM pads but still provide more than adequate braking power for any normal driving condition.
I did keep the stock pads in case I ever decide to put some track time on the car, or in the event the cmax's didn't perform. Time will tell and if I find that they are wearing the rotors faster than the OEM pads I will swap them back.
On a side note, the girlfriend wanted to go with me while I bedded the brake pads and didn't believe that I was actually going to speed up to 80 mph and slam on the brakes a few times. That was pretty funny :P
Old Nov 29, 2012 | 05:11 PM
ugakirk's Avatar
They're ok.
I will promise you the rotors will not wear faster. Brake dust is actually a lot of rotor and pads. The OEM pads create a lot of dust because they are so hard, creating more noise and wear on the rotors. The C-maxs are much softer than stock.
How much did they run at Autozone?
Old Nov 29, 2012 | 05:58 PM
Hmm, good to know. I had read the speculations that they were harder on the rotors but never came across any threads confirming it or not.
They were about 54 bucks each set. Which I thought was kind of weird that the rears were the same price as the fronts.
Originally Posted by ugakirk
They're ok.
Old Nov 30, 2012 | 07:34 PM
GsrJake's Avatar
I got mine from autoze, way better then stock
Old Nov 30, 2012 | 07:55 PM
Johnr352's Avatar
Question...are you picking duralast pads cause they are cheap or because they brake Bette than oem pads?
Old Dec 1, 2012 | 06:05 AM
Smike's Avatar
I guaranty they do not stop as well as OE or other aftermarket offerings. Dust is subjective. Stopping power (coefficient of drag) is not.
Old Dec 1, 2012 | 07:37 PM
ugakirk's Avatar
O yea.. Not even close to stock stopping power. But they create a lot less dust and are quieter than stock pads.
Old Dec 4, 2012 | 12:03 AM
►EvolutionX◄'s Avatar
They're ok.
Uhh, Not too sure about this one cap'n kirk
Ceramic Pads will cause accelerated wear of brake rotors, the ceramic material is by nature a harder compound and therefore wears slower than semi-metallic pads. The friction of the pad on the rotor is what slows down your vehicle, so that friction has to wear some component, wether rotor or pad.
Note: This is dependent on the composition of your rotor as well.
Old Dec 4, 2012 | 07:38 AM
Kreeker's Avatar
Why would you guy duralast pads if you could buy Stoptech Streets for $64 shipped?
Old Dec 4, 2012 | 07:51 AM
Smike's Avatar
I disagree here from a chemistry stand point. Pad hardness is determined by the design of the pad material - ceramic or not. Depends how it was developed. Semi-metallics can turn into carbide when hot. Ceramics have much better heat sinking ability.
Old Dec 4, 2012 | 02:23 PM
AWDTerror's Avatar
Also I'm pretty sure that they aren't a true ceramic pad.
Old Dec 7, 2012 | 01:06 PM
TTMride's Avatar
may have to try them next time
Old Dec 7, 2012 | 04:54 PM
Iowa999's Avatar
<- is staying out of this discussion because he thought Duralast was a brand of condom....
Old Dec 8, 2012 | 04:34 PM
Noe18's Avatar
Zach S
Oct 15, 2015 07:57 AM
funks
58
Dec 20, 2012 11:34 AM
tsitalon1
73
Dec 12, 2010 11:54 AM
AoyamaJPN
10
Dec 9, 2009 10:33 PM
DGFUNNY70
Jul 8, 2009 07:37 PM
