Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Noob questions about tire sizing. please help
Old Feb 20, 2013 | 12:10 PM
dudutz's Avatar
Recently I just purchased a used 2010 evo x, and it comes with stock wheels with winter tires on (bridgestone blizak 235/40/18), so I'm in the market for all season tires and planing to lower the car using swift spring spec r. what size tires should I purchase for it to fit on the stock wheels without rubbing or doing any fender modification? will 245/40/18 fit fine or 245/35/18 is better? is it possible also if I go wider tires at 255/40/18 or 255/35/18? thank you for your input
Old Feb 20, 2013 | 12:17 PM
Sunwalker12's Avatar
You can run 255s on the stock rim but thats about as wide as you can go. If your planning on going wider a new set of wheels are needed. As far as the profile.. that's your choice.
Old Feb 20, 2013 | 01:20 PM
dudutz's Avatar
^^ thank you sir
Old Feb 20, 2013 | 02:07 PM
Gqracer's Avatar
245/40 is the stock size.
Old Feb 20, 2013 | 02:47 PM
evo_yoshi15's Avatar
+1 sunwalker i think that is the biggest i could go on stock trim but also depends wat ur goal is as in looks for the car if ur into the stance thing or aggressive gl wit this
Old Feb 20, 2013 | 06:21 PM
dudutz's Avatar
I'm not into stance or aggressive setup for now, maybe sometime in the future for now Im planing to lower the car a bit by using swift spec r spring to remove the wheels gap. before pulling the trigger on the new tires, I just want to confirm once again if I were to choose 255/35/18 on the stock wheels, I should be ok with no rubbing or fender modification? thanks again guys. pardon me for my noobness lol
Old Feb 20, 2013 | 06:40 PM
Drew1's Avatar
People run wider tires for better traction and for the wheels to look wide from behind. Other than that they are a waste. You will see worse mpg and just pay more for the tires.
Also if you didn't know the first number is width (in mm roughly), second number is height (as a percentage of the width) and third number is wheel size.
Old Feb 20, 2013 | 07:55 PM
dudutz's Avatar
thanks drew1 for the info
sonicrx
For Sale - Wheels / Tires
Feb 8, 2017 03:48 PM
TxFAkuma
11
Nov 30, 2016 11:16 AM
an2ny
Apr 28, 2015 04:43 PM
an2ny
Apr 27, 2015 04:21 PM
mot
Aug 8, 2006 05:39 PM
