Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
car pulls hard to right when given gas
Old Feb 15, 2014 | 06:55 AM
airman9911's Avatar
Have a problem with my evo pulling hard to the right when I give it gas to say, pass somebody. But, when im just driving in a straight line it holds true. Already had it aligned and all that. Any suggestions on what it is? And it only started doing this after I blew the 2 left side tires out on a divider curb when some cut me off at a light, before then i didnt have this problem.
Old Feb 15, 2014 | 05:30 PM
littlezrexer's Avatar
its the tires. swap the tires that are new on the same axle. (rear or front) may have to have 2 tires switched depending on if they are directional tires.
Old Feb 15, 2014 | 06:06 PM
Iowa999's Avatar
The other thing to do, besides rotating tires, is to put the display into S-AWC mode and make sure that the AYC isn't doing anything crazy.
Old Feb 15, 2014 | 09:55 PM
airman9911's Avatar
Ops Ck good on the AYC and S-AWC.
Old Feb 15, 2014 | 09:56 PM
airman9911's Avatar
I was talkin to a buddy about it and he said something like torsion link, or idler arms effd up. I dont remember which he said. Could those be possible causes?
Old Feb 15, 2014 | 09:58 PM
airman9911's Avatar
Theyre used tires and both sets have about the same amount of tread wear. Theyre 2 differwnt makes of tires...
Old Feb 15, 2014 | 10:00 PM
Iowa999's Avatar
Then I'd do as suggested above. Personally, I'd put the two new tires on the front of the car, even if they're directional. Directionality really only has an effect in rain, so go easy in rain until you can wear them down closer to the others.
Or put the new ones on the rear and go to an autocross and drift a few pin-turns. That'll wear them down quickly.
edit - my post crossed with the immediate previous ... who the heck sold you mismatched tires for an AWD? In any event, you need to match the tires at each end at a minimum.
Old Feb 15, 2014 | 10:03 PM
Iowa999's Avatar
Doubtful if the car re-aligned easily. But I shouldn't assume anything. How far out of alignment was the car after whatever happened to blow the left-side tires?
Old Feb 16, 2014 | 08:37 AM
It's the wear pattern in the tires... Swap them like I said.
Old Feb 16, 2014 | 12:41 PM
airman9911's Avatar
mechanic at the shop on base said that it wasnt too bad knocked out.
Old Feb 16, 2014 | 12:42 PM
airman9911's Avatar
Ok ok. Will do. Thanks for the input.
Coxor
Sep 22, 2020 01:13 PM
evoviiihan
10
Oct 22, 2016 10:00 PM
usacchamp
Jul 27, 2015 06:41 PM
Jehuty
Lancer Troubleshooting
36
Mar 18, 2013 06:57 PM
dmitirygolos
10
Jan 4, 2011 11:00 PM
